INDUCTRIX FPV (NOT PRO)
20 Sep 2017 19:06 #64549 by jimx3
INDUCTRIX FPV (NOT PRO) was created by jimx3
my first try on learning mixer. decided to do it on my beginner inductrix fpv. being that this product is aimed at beginners, i thought of sharing my mixer.
notes:
hold 2 position switch set as arm/disarm
fmod 2 position switch set as flight mode switch level/acro modes (inductrix fpv red light indicator will turn on and off depending on selected flight mode)
hope this works for you cheers
tags: blade inductrix fpv model config whoop.ini inductrix.ini
15 Oct 2017 20:08 #65080 by X_Marine
Replied by X_Marine on topic INDUCTRIX FPV (NOT PRO)
Thanks Jim,
Haven't tried it yet but anxious to do so.
I'll be using with the FPV Plus which also has the "meow" mode. So I'll still have to add that but this looks like a good starting point.
Many thanks.
X/BillyD..
01 Mar 2018 17:02 #67844 by Drons
Replied by Drons on topic INDUCTRIX FPV (NOT PRO)
Hi Jim and X_marine.
I have my Inductrix FPV+ and i have problems seting up the 3 positions switch to control flight modes using my Jumper T8SG.
Could you help me ???
18 Mar 2018 09:53 #68177 by X_Marine
Sorry Drons,
I got dragged away from ever getting mine setup properly so I wouldn't be much help.
In one of the threads on the subject I remember posting a link or pointing some others to a well done article on the subject that was the most help in getting this thru my thick skull. ')
Iir, it was in the tutorial section, maybe..
But just search for post I have made.
Hope that helps you out a little.
You can be sure the answers are here, it just takes a lot of reading.
Best of luck with it.
X/BillyD..
18 Mar 2018 10:16 #68179 by X_Marine
Hey, I looked that up and below is info.
"I have found "Deconstructing Deviation Model files" by Jeffrey Diehl," this is very helpful..
GL
X/BillyD..
02 Jun 2018 21:37 #69521 by N7QWT
Replied by N7QWT on topic INDUCTRIX FPV (NOT PRO)
Here is my first .ini that works as intended.
It's a kluge of a file found here and what I put together myself.
Model: Blade Inductrix
Switch G: Down/Back = Safe/E-Stop
Switch G: Up/Forward = Arm
Switch D: Down = A.E.R. at 60%
Switch D: Center = A.E.R. at 80%
Switch D: Up = A.E.R. at 100%
Switch H: Toggle to go between Level and Acro.
A.E.R. all have a EXPO on them.
Radio is a T8SG V2 Plus
24 Jul 2018 21:15 #69955 by erich
Replied by erich on topic INDUCTRIX FPV (NOT PRO)
N7QWT wrote: Here is my first .ini that works as intended.
Hi, it works great, thanks!
By the way, what A.E.R. does stand for (Aileron, Elevator, Rudder?)?
