E‑flite UMX Timber Basic
15 Oct 2017 19:58 #65079 by RSGAZ
E‑flite UMX Timber Basic was created by RSGAZ
I have modified an .ini from an A-10 Warthog to use for the UMX Timber 1.5. I am new to the deviation and was looking for feedback as to whether it will work. Waiting for delivery of the Timber so I cannot test it.
"Slow" Flaps, gear, FMOD0,1&2 for an A3Super flight stabilizer + Aux4 Pot to tune Flight Stabilizer Gain in flight. Aileron, rudder and elevator all with duel rate + expo.
Thanks.
name=TIMBER
mixermode=Advanced
type=plane
[radio]
protocol=DSMX
num_channels=10
fixed_id=8675309
tx_power=150mW
[protocol_opts]
Telemetry=OFF
[channel1]
safetysw=!Virt1
safetyval=-100
template=simple
[mixer]
src=THR
dest=Ch1
[channel2]
reverse=1
scalar=48
scalar-=48
template=expo_dr
[mixer]
src=AIL
dest=Ch2
curvetype=expo
points=50,50
[mixer]
src=AIL
dest=Ch2
switch=AIL DR0
curvetype=expo
points=50,50
[mixer]
src=AIL
dest=Ch2
switch=AIL DR1
scalar=57
curvetype=expo
points=50,50
[channel3]
reverse=1
scalar=40
scalar-=40
template=complex
[mixer]
src=ELE
dest=Ch3
switch=ELE DR0
curvetype=expo
points=30,30
[mixer]
src=ELE
dest=Ch3
switch=ELE DR1
scalar=50
curvetype=expo
points=30,30
[mixer]
src=Virt2
dest=Ch3
muxtype=add
[channel4]
scalar=40
scalar-=40
template=expo_dr
[mixer]
src=RUD
dest=Ch4
curvetype=expo
points=20,20
[mixer]
src=RUD
dest=Ch4
switch=RUD DR0
curvetype=expo
points=20,20
[mixer]
src=RUD
dest=Ch4
switch=RUD DR1
scalar=55
curvetype=expo
points=20,20
[channel5]
template=simple
[mixer]
src=!GEAR0
dest=Ch5
curvetype=expo
points=0,0
[channel6]
speed=5
scalar-=75
template=complex
[mixer]
src=MIX0
dest=Ch6
switch=MIX0
curvetype=fixed
[mixer]
src=MIX1
dest=Ch6
switch=MIX1
scalar=-20
curvetype=fixed
[mixer]
src=MIX2
dest=Ch6
switch=MIX2
scalar=-100
curvetype=fixed
[channel7]
template=complex
[mixer]
src=FMODE0
dest=Ch7
switch=FMODE0
scalar=-100
curvetype=fixed
[mixer]
src=FMODE0
dest=Ch7
switch=FMODE1
scalar=0
curvetype=fixed
[mixer]
src=FMODE2
dest=Ch7
switch=FMODE2
curvetype=fixed
[channel8]
max=100
min=-100
template=simple
[mixer]
src=AUX4
dest=Ch8
curvetype=expo
points=0,0
[channel10]
scalar-=100
template=complex
[mixer]
src=RUD
dest=Ch10
curvetype=expo
points=80,80
[virtchan1]
name=FLAP TO E
[virtchan2]
template=complex
[mixer]
src=ELE
dest=Virt2
switch=MIX0
usetrim=0
curvetype=3point
points=0,0,0
[mixer]
src=ELE
dest=Virt2
switch=MIX1
usetrim=0
curvetype=3point
points=-15,-15,-15
[mixer]
src=ELE
dest=Virt2
switch=MIX2
usetrim=0
curvetype=3point
points=-30,-30,-30
[mixer]
src=AIL
dest=Virt2
usetrim=0
muxtype=delay
curvetype=fixed
[trim1]
src=LEFT_V
pos=TRIMLV+
neg=TRIMLV-
[trim2]
src=RIGHT_V
pos=TRIMRV+
neg=TRIMRV-
[trim3]
src=LEFT_H
pos=TRIMLH+
neg=TRIMLH-
[trim4]
src=RIGHT_H
pos=TRIMRH+
neg=TRIMRH-
[trim5]
src=Ch10
pos=TRIM_R+
neg=TRIM_R-
step=10
[timer1]
type=countdown
src=THR
time=240
[timer2]
src=THR
[datalog]
switch=None
rate=1 sec
[safety]
Auto=min
[gui-128x64]
V-trim=59,13,1
H-trim=5,60,3
V-trim=64,13,2
H-trim=74,60,4
Small-box=0,17,Ch3
Small-box=0,26,Timer1
Small-box=0,35,Timer2
Model=76,17
Battery=102,1
Toggle=49,18,0,3,0,RUD DR
Toggle=49,30,0,5,0,ELE DR
Toggle=69,30,0,4,0,AIL DR
Toggle=69,18,2,65,129,MIX
Toggle=69,42,1,64,128,FMODE
TxPower=102,7
Toggle=49,42,0,8,0,GEAR
H-trim=5,55,5
Small-box=0,44,Ch8
quickpage1=Telemetry monitor
quickpage2=Channel monitor
quickpage3=Trims
29 Dec 2017 17:11 #66643 by Brett_N
Replied by Brett_N on topic E‑flite UMX Timber Basic
RSGAZ, did you have a chance to test this out?
My Timber will be here next week :-)
03 Jan 2018 14:04 #66695 by RSGAZ
Replied by RSGAZ on topic E‑flite UMX Timber Basic
No not yet. I have been looking everywhere to get the correct flap adjustment. Mine will be here Friday and will test it. See attached for the best that I have for now. It all matches with UMX Timber manual for channels, safe and flaps. I am just not sure of the slow part. Again, the .ini has not been tested.
06 Jan 2018 19:46 #66745 by RSGAZ
Tested and working. Slow flaps, as3x on FMOD, GEAR=safe, MIX=flaps.
name=TIMBER
mixermode=Advanced
type=plane
[radio]
protocol=DSMX
num_channels=7
fixed_id=8675309
tx_power=150mW
[protocol_opts]
Telemetry=Off
[channel1]
safetysw=!Virt1
safetyval=-100
template=simple
[mixer]
src=THR
dest=Ch1
[channel2]
template=expo_dr
[mixer]
src=AIL
dest=Ch2
scalar=70
curvetype=expo
points=50,50
[mixer]
src=AIL
dest=Ch2
switch=AIL DR1
scalar=50
curvetype=expo
points=50,50
[channel3]
template=expo_dr
[mixer]
src=ELE
dest=Ch3
scalar=70
curvetype=expo
points=40,40
[mixer]
src=ELE
dest=Ch3
scalar=50
curvetype=expo
points=50,50
[channel4]
template=expo_dr
[mixer]
src=RUD
dest=Ch4
scalar=70
curvetype=expo
points=40,40
[mixer]
src=RUD
dest=Ch4
switch=AIL DR1
scalar=50
curvetype=expo
points=50,50
[channel5]
template=simple
[mixer]
src=!GEAR0
dest=Ch5
curvetype=expo
points=0,0
[channel6]
speed=5
scalar-=100
template=complex
[mixer]
src=MIX0
dest=Ch6
switch=MIX0
scalar=-100
curvetype=fixed
[mixer]
src=MIX1
dest=Ch6
switch=MIX1
scalar=30
curvetype=fixed
[mixer]
src=MIX2
dest=Ch6
switch=MIX2
scalar=75
curvetype=fixed
[channel7]
template=complex
[mixer]
src=FMODE0
dest=Ch7
switch=FMODE0
scalar=-80
curvetype=fixed
[mixer]
src=FMODE1
dest=Ch7
switch=FMODE1
scalar=0
curvetype=fixed
[mixer]
src=FMODE2
dest=Ch7
switch=FMODE2
curvetype=fixed
[trim1]
src=LEFT_V
pos=TRIMLV+
neg=TRIMLV-
[trim2]
src=RIGHT_V
pos=TRIMRV+
neg=TRIMRV-
value=-8,0,0
[trim3]
src=LEFT_H
pos=TRIMLH+
neg=TRIMLH-
[trim4]
src=RIGHT_H
pos=TRIMRH+
neg=TRIMRH-
[trim5]
src=Ch10
pos=TRIM_R+
neg=TRIM_R-
step=10
[timer1]
type=countdown
src=THR
resetsrc=RUD DR1
time=360
[timer2]
src=THR
[datalog]
switch=None
rate=1 sec
[safety]
Auto=min
[gui-128x64]
V-trim=59,13,1
H-trim=5,60,3
V-trim=64,13,2
H-trim=74,60,4
Small-box=0,17,Ch3
Model=76,17
Battery=102,1
TxPower=102,7
H-trim=5,55,5
Small-box=0,44,Ch8
quickpage3=Trims
17 Aug 2018 00:17 #70294 by mnherky
Replied by mnherky on topic E‑flite UMX Timber Basic
works great, Tanks
Time to create page: 0.333 seconds
