Jumper T8SG V2+ V911, 2018
- hysterio
08 Sep 2018 17:50 #70744
by hysterio
Jumper T8SG V2+ V911, 2018 was created by hysterio
Hello to all,
i recently launched myself into a first foray into drone building and have been stumped ever since i finished putting together my first configuration.
I am trying to bind a T8SG V2 (which has the A7105 included with no added module) with the V911 2-servo PCD circuit to control elevator flaps and motor.
The problem is that when i turn on the transmitter after plugging the battery into the v911, the red light never achieves a solid red, it maintains a slow blinking, despite a beep from the transmitter after the 3 second binding process.
I have included the required parameters in hardware.ini and tx.ini and tried a model configuration found on this forum (all data below).
I am completely stumped at this point and would appreciate any help/indication!!!
Cheers,
Nic
Hardware.ini:
;enable-haptic=1
;switch_types: 3x4, 3x3, 3x2, 3x1, 2x8, 2x7, 2x6, 2x5, 2x4, 2x3, 2x2, 2x1, potx2, potx1
;Add nostock if stock FMOD and HOLD switches have been removed.
extra-switches = nostock
extra-switches = 3x4
extra-switches = 2x2
extra-switches = potx2
;Audio player connected to UART (Devo12/S internally, others via trainer port): audiofx, dfplayer
;voice=
;Enable if audio device is wired to uart5 instead of ppm on devo7e-256
;voice-uart5=1
;extra-buttons=
[modules]
; enable-cyrf6936 = B12
; has_pa-cyrf6936 = 1
enable-a7105 = A13
has_pa-a7105 = 1
enable-cc2500 = A14
has_pa-cc2500 = 1
enable-nrf24l01 = A15
has_pa-nrf24l01 = 1
; enable-multimod = A13
tx.ini:
current_model=5
language=0
music_shutdown=0
mode=1
brightness=7
contrast=6
volume=2
audio_vol=1
vibration=1
power_alarm=0
batt_alarm=4100
batt_critical=3900
batt_warning_interval=30
splash_delay=35
[modules]
enable-a7105=A13
has_pa-a7105=1
enable-cc2500=-0
has_pa-cc2500=0
[calibrate1]
max=4064
min=2
zero=1987
[calibrate2]
max=4095
min=178
zero=2208
[calibrate3]
max=4095
min=56
zero=2064
[calibrate4]
max=4033
min=5
zero=2062
[calibrate5]
max=4095
min=0
zero=2889
[calibrate6]
max=4095
min=0
zero=1575
[autodimmer]
timer=40000
dimvalue=0
[countdowntimersettings]
prealerttime=30000
prealertinterval=10000
timeupinterval=10000
[telemetry]
temp=celcius
length=meters
alertinterval=15
Cheers,
Nic
Hardware.ini:
;enable-haptic=1
;voice=
;voice-uart5=1
;extra-buttons=
[modules]
enable-a7105 = A13
has_pa-a7105 = 1
enable-cc2500 = A14
has_pa-cc2500 = 1
has_pa-nrf24l01 = 1
tx.ini:
current_model=5
language=0
music_shutdown=0
mode=1
brightness=7
contrast=6
volume=2
audio_vol=1
vibration=1
power_alarm=0
batt_alarm=4100
batt_critical=3900
splash_delay=35
[modules]
enable-a7105=A13
has_pa-a7105=1
enable-cc2500=-0
has_pa-cc2500=0
[calibrate1]
max=4064
min=2
zero=1987
[calibrate2]
max=4095
min=178
zero=2208
[calibrate3]
max=4095
min=56
zero=2064
[calibrate4]
max=4033
min=5
zero=2062
[calibrate5]
max=4095
min=0
zero=2889
[calibrate6]
max=4095
min=0
zero=1575
[autodimmer]
timer=40000
dimvalue=0
prealerttime=30000
[telemetry]
temp=celcius
length=meters
alertinterval=15
Model Configs
- Jumper T8SG V2+ V911, 2018
