Jumper t8sg v2 plus setup
16 Apr 2019 14:58 #73922 by oldjoe
Jumper t8sg v2 plus setup was created by oldjoe
Trying to setup t8sg v2 plus to xk a800. The xk has 6g and 3g mode. Does anyone know how to set this up on a switch? Thanks.
23 Apr 2019 18:35 - 28 Apr 2019 18:35 #74116 by stargate7
Replied by stargate7 on topic Jumper t8sg v2 plus setup
Loading this setup, everything works fine with my XK A800 :P
For my setup these are the switcher commands: H =Throttle Cut G =Throttle Cut    A0 =6G mode Low Rate    A1 =6G mode High Rate    A2 =3D mode High Rate
8ch: -100= 6G/Limit Angle   +100= 3D/Full Controll
Last edit: 28 Apr 2019 18:35 by stargate7.
23 Apr 2019 18:45 #74117 by oldjoe
Replied by oldjoe on topic Jumper t8sg v2 plus setup
So do you load this through usb or can you do it manually? Thanks.
23 Apr 2019 20:58 #74118 by stargate7
This is an ini file you can copy it to the t8sg folder and make some variations based on your preferences.
load via usb in the models folder, just enter the number where you want to put it, and then copy and replace.
28 Apr 2019 11:00 #74160 by oldjoe
Finally got it working by using channel 8 on transmitter.
12 Feb 2020 14:09 #75909 by ltonini80
Replied by ltonini80 on topic Jumper t8sg v2 plus setup
Sorry, can you help me?
In your file at line 29 there is 'scalar-=100'...
So why the - is before =
Thank you for help me.
14 Feb 2020 13:59 #75921 by eried
Replied by eried on topic Jumper t8sg v2 plus setup
It seems "scalar-=" could be used for CHAN_SCALAR_NEG
github.com/DeviationTX/deviation/blob/13.../config/model.c#L153
Time to create page: 0.198 seconds
