Jumper t8sg v2 plus setup
- oldjoe
16 Apr 2019 14:58 #73922
by oldjoe
Jumper t8sg v2 plus setup was created by oldjoe
Trying to setup t8sg v2 plus to xk a800. The xk has 6g and 3g mode. Does anyone know how to set this up on a switch? Thanks.
- stargate7
23 Apr 2019 18:35 - 28 Apr 2019 18:35 #74116
by stargate7
Replied by stargate7 on topic Jumper t8sg v2 plus setup
Loading this setup, everything works fine with my XK A800
For my setup these are the switcher commands: H =Throttle Cut G =Throttle Cut A0 =6G mode Low Rate A1 =6G mode High Rate A2 =3D mode High Rate
8ch: -100= 6G/Limit Angle +100= 3D/Full Controll
Last edit: 28 Apr 2019 18:35 by stargate7.
- oldjoe
23 Apr 2019 18:45 #74117
by oldjoe
Replied by oldjoe on topic Jumper t8sg v2 plus setup
So do you load this through usb or can you do it manually? Thanks.
- stargate7
23 Apr 2019 20:58 #74118
by stargate7
This is an ini file you can copy it to the t8sg folder and make some variations based on your preferences.
load via usb in the models folder, just enter the number where you want to put it, and then copy and replace.
- oldjoe
28 Apr 2019 11:00 #74160
by oldjoe
Finally got it working by using channel 8 on transmitter.
- ltonini80
12 Feb 2020 14:09 #75909
by ltonini80
Replied by ltonini80 on topic Jumper t8sg v2 plus setup
Sorry, can you help me?
In your file at line 29 there is 'scalar-=100'...
So why the - is before =
Thank you for help me.
- eried
14 Feb 2020 13:59 #75921
by eried
Replied by eried on topic Jumper t8sg v2 plus setup
It seems "scalar-=" could be used for CHAN_SCALAR_NEG
github.com/DeviationTX/deviation/blob/13.../config/model.c#L153
Time to create page: 0.303 seconds
Model Configs
- Jumper t8sg v2 plus setup
