Setting up XK 110 and XK K130 on Jumper T8Sg
06 May 2020 22:38 #76256 by Sidwellmu
Please help with setting up XK K110 and XK K130 helicoptesr. I seleted 90 degree swash but the heli servos are not responding properly.
Please help or send an .ini file for the successful setup of XK helicopters (XK K110 and XK K130)
Regards
Sid
07 May 2020 01:39 #76260 by gdenton
Replied by gdenton on topic Setting up XK 110 and XK K130 on Jumper T8Sg
Leave SwashType set to 'None', the swash mixing is in the receiver board.
I don't have a T8Sg transmitter but here's the mixes from my Devo 6S that should help you get started.
channel5 = 3D/6G mode.
channel6 = collective pitch , adjust as needed.
You may need to change the switches in channel3 & 5.
name=H K110
mixermode=Advanced
[radio]
protocol=S-FHSS
num_channels=8
fixed_id=123456
tx_power=100mW
[protocol_opts]
Freq-Fine=0
Freq-Coarse=0
[channel1]
template=expo_dr
[mixer]
src=AIL
dest=Ch1
curvetype=expo
points=20,20
[channel2]
template=expo_dr
[mixer]
src=ELE
dest=Ch2
curvetype=expo
points=20,20
[channel3]
safetysw=MIX0
safetyval=-100
template=expo_dr
[mixer]
src=THR
dest=Ch3
curvetype=5point
points=-100,0,100,100,100
[channel4]
template=simple
[mixer]
src=RUD
dest=Ch4
scalar=125
[channel5]
template=simple
[mixer]
src=GEAR0
dest=Ch5
curvetype=expo
points=0,0
[channel6]
template=expo_dr
[mixer]
src=THR
dest=Ch6
curvetype=5point
points=-20,-10,0,25,50
07 May 2020 08:29 #76262 by Sidwellmu
Replied by Sidwellmu on topic Setting up XK 110 and XK K130 on Jumper T8Sg
Thank you very much. I will work on it.
Time to create page: 0.312 seconds
