WLTOYS V912 & EMAX TINYHAWK II Config on Jumper T8
03 Dec 2020 16:50 - 03 Dec 2020 17:00 #77082 by Tinee
I attached my config for V912 Helicopter and TinyHawk II done on T8SG Plus. I'm a novice and I took time to do it. So could be helpful for someone else.
Thanks to @aw73 for the V912 source.
By the Way, on the V912 I'm still not able to reproduce the switch/mix for light on/light off. Is someone could help me on it ?
Last edit: 03 Dec 2020 17:00 by Tinee.
13 Dec 2020 16:22 #77109 by Denis22
I'am novice too)) I have T8SG and V912 brush version. Today I tryed setup transmitter to work with V912. And one servo is channel 1, another channel 2. In other models (V911S), XK K110 channel is AIL or ELE. But in this model I must send mixed value. Is your V912 fly correct with your settings from files? Maybe yes, because in your file I see [swash]
type=120
ele_inv=1
ail_inv=1
col_inv=1
but this settings are in Standard mode, in Advanced mode this option is expected
About light - try change value in channel 5. I'll try too do it later
15 Dec 2020 13:45 #77113 by Tinee
Thanks for you feedback.
Yes, my profile work very well and the mode to change from low to high mode is working well.
I didn' try the advanced profile, but I will test when possible.
Let me know if you do it before me.
Tinee
Time to create page: 0.101 seconds
