jumper t8sg v3 plus telemetry alarm not beeping
16 Dec 2020 18:38 #77121 by ravenspired
Hello all,
I successfully bound my bugs 3 to my transmitter and everything is working fine except for the telemetry. The telemetry is viewable on the transmitter and it blinks during an alarm, but the transmitter does not beep. Is there something I missed when setting up the telemetry alarm? Thanks in advance.
16 Dec 2020 21:59 #77122 by propnut
Have you checked your volume settings ?
By the way, you can add full voice support to the radio by simply installing an SD-Card along with the voice files. Look under the Wiki section for voice support
16 Dec 2020 22:04 #77123 by ravenspired
Replied by ravenspired on topic jumper t8sg v3 plus telemetry alarm not beeping
Yes, I have full volume for everything. I just want beeping, not any speech. I will also note that the transmitter does not make any noise when turning on, but when I press the trim buttons, it does make beeps.
27 Dec 2020 00:37 #77141 by ravenspired
UPDATE:
I was able to fix this by editing two lines in the hardware.ini file in the transmitter.
In your hardware.ini file, change voice to have no value, and change voice-uart5 to have a value of 1, like so:
voice=
and
voice-uart5=1.
Now it beeps and buzzes!
Time to create page: 0.083 seconds
