Tarot/Align 450 DFC w/ Walkera 2702v 3-axis
03 Oct 2012 21:46 - 04 Oct 2012 17:04 #1961 by flint723
Tarot 450 dfc:
rx2702v-d 3-axis receiver.
CC Ice 50 governed to 3100rpm with 9.3:1 gear ratio, 3400kv motor. You will need to set up different throttle curves if you are not using a governor.
ds415m cyclic servos. savox sh-1257mg tail servo.
Ail, Ele, or Col(Pitch) might have to be inverted in the swash settings; be sure your swash is tilting in the right directions.
No expo so it could be twitchy.
Do not use this unless you are at least a bit familiar with deviation and setting up a 2702v 3-axis, I don't want anyone to get hurt.
Edit: I have re-uploaded the .ini to not include my subtrims and ccpm offesets because anyone else who uses this will have to set up different ones i'm sure.
File Attachment:
File Name: T450.ini
File Size:4 KB
Last edit: 04 Oct 2012 17:04 by flint723.
04 Oct 2012 12:09 #1978 by FDR
Very interesting setup!
Just a note: since you have identical picth curves for FMODE1 and FMODE2, they could be done with one curve if you set the switch to "!FMODE0" (i.e. not fmode0)
04 Oct 2012 14:40 #1983 by flint723
Replied by flint723 on topic Tarot/Align 450 DFC w/ Walkera 2702v 3-axis
I guess it was just habit to set it up that way lol. Then if I ever did want to put different pitch curves in it would be a quick click to adjust.
04 Oct 2012 14:51 #1984 by FDR
Yep, it's fine and quite reasonable, I just want to spread some knowlage about the functions... ;)
04 Oct 2012 16:57 - 04 Oct 2012 17:17 #1988 by flint723
Oh I see what you mean. I did not know that was an option. Thanks!
Also if you were wondering about the offset on the ele ccpm mixing it's the only way I found to be able to get my servo horns to 90 degrees at mid stick, as the subtrim with a max value of 10 won't do it. Is there a way to make the the subtrim more than 10? Maybe the offset is a better way anyway. It does seem to work fine with my setup even though the graph that is displayed shows it's cut off on the bottom. I am not sure if the output actually cuts off like that, or if it just isn't displayed on the graph.
I decided to re-upload the ini without the offset in the ele ccpm mixing. Also without any subtrims.
Edit: I checked out the raw channel output page and I see that it does not cut off when you offset it, the graph just can't display it. maybe the graph should display a -120 to +120 scale or something.
Last edit: 04 Oct 2012 17:17 by flint723.
Time to create page: 0.075 seconds
