Tarot/Align 450 DFC w/ Walkera 2702v 3-axis
- flint723
03 Oct 2012 21:46 - 04 Oct 2012 17:04 #1961
by flint723
Tarot/Align 450 DFC w/ Walkera 2702v 3-axis was created by flint723
Tarot 450 dfc:
rx2702v-d 3-axis receiver.
CC Ice 50 governed to 3100rpm with 9.3:1 gear ratio, 3400kv motor. You will need to set up different throttle curves if you are not using a governor.
ds415m cyclic servos. savox sh-1257mg tail servo.
Ail, Ele, or Col(Pitch) might have to be inverted in the swash settings; be sure your swash is tilting in the right directions.
No expo so it could be twitchy.
Do not use this unless you are at least a bit familiar with deviation and setting up a 2702v 3-axis, I don't want anyone to get hurt.
Edit: I have re-uploaded the .ini to not include my subtrims and ccpm offesets because anyone else who uses this will have to set up different ones i'm sure.
Last edit: 04 Oct 2012 17:04 by flint723.
04 Oct 2012 12:09 #1978
Replied by FDR on topic Tarot/Align 450 DFC w/ Walkera 2702v 3-axis
Very interesting setup!
Just a note: since you have identical picth curves for FMODE1 and FMODE2, they could be done with one curve if you set the switch to "!FMODE0" (i.e. not fmode0)
- flint723
04 Oct 2012 14:40 #1983
by flint723
Replied by flint723 on topic Tarot/Align 450 DFC w/ Walkera 2702v 3-axis
I guess it was just habit to set it up that way lol. Then if I ever did want to put different pitch curves in it would be a quick click to adjust.
04 Oct 2012 14:51 #1984
Yep, it's fine and quite reasonable, I just want to spread some knowlage about the functions...
- flint723
04 Oct 2012 16:57 - 04 Oct 2012 17:17 #1988
by flint723
Oh I see what you mean. I did not know that was an option. Thanks!
Also if you were wondering about the offset on the ele ccpm mixing it's the only way I found to be able to get my servo horns to 90 degrees at mid stick, as the subtrim with a max value of 10 won't do it. Is there a way to make the the subtrim more than 10? Maybe the offset is a better way anyway. It does seem to work fine with my setup even though the graph that is displayed shows it's cut off on the bottom. I am not sure if the output actually cuts off like that, or if it just isn't displayed on the graph.
I decided to re-upload the ini without the offset in the ele ccpm mixing. Also without any subtrims.
Edit: I checked out the raw channel output page and I see that it does not cut off when you offset it, the graph just can't display it. maybe the graph should display a -120 to +120 scale or something.
Last edit: 04 Oct 2012 17:17 by flint723.
Time to create page: 0.087 seconds
Model Configs
- Tarot/Align 450 DFC w/ Walkera 2702v 3-axis
