Walkera New V120D02s: beginner settings
13 Oct 2012 00:13 - 13 Oct 2012 00:14 #2189 by marc
This beginner configuration is based on the 8k-template in the deviation user manual and on the beginner configuration by TomZ at rcgroups.
- FMode 0: Throttle max. 62, pitch curve -8 to 56, no wind.
- FMode 1: Throttle max. 75, pitch curve -22 to 65,
- (FMode 3: Throttle V-curve 95-13-95, linear pitch curve -70 to 72)
- Gyro sensitivity on Mix Switch: 75-68-60.
- Throttle hold: see mixer on ch 3.
Correct icon must be in directory /modelico.
Marc
Last edit: 13 Oct 2012 00:14 by marc. Reason: upload ini
07 Nov 2012 21:19 - 07 Nov 2012 21:43 #2764 by Hexperience
Replied by Hexperience on topic Walkera New V120D02s: beginner settings
I thought this would be a single servo / no ccpm heli?
--- edit---
Sorry.. I guess it is. I see that under the Helicopter Type-> Swash type it's set to None. But I got confused because the channels are showing cyclic1,2 and 3.
I'm used to calling them Aileron, Elevator and Pitch when the swash type is set to none.
--- edit ---
Ok now I see that the channels are SET to cyclic... Is that so dual rates only need to be set on the virtual channel?
Last edit: 07 Nov 2012 21:43 by Hexperience.
30 Aug 2016 16:11 #53286 by jimw1956
Replied by jimw1956 on topic Walkera New V120D02s: beginner settings
What radio is this for, will it work on Devo 7e?
30 Aug 2016 17:42 #53290 by Thomas.Heiss
Replied by Thomas.Heiss on topic Walkera New V120D02s: beginner settings
Try it - it just depends on switches :-)
The model.ini is based on the 6ch advanced heli template which also uses for FBL (CCPM NONE) the virtual channels cyclic1-3.
It is the same as you would directly load the heli template in the model setup editor.
Yes, if you use that then most of the settings like D/R, pitch curves are set on the virtual channels.
Time to create page: 0.199 seconds
