quanum venture with devo 10 lemon rx ppm
01 Nov 2014 17:07 #26249 by mikemacwillie
quanum venture with devo 10 lemon rx ppm was created by mikemacwillie
It'll bind with the DSMX or DSM2 protocol depending on which Lemon RX you have.
08 Nov 2014 07:13 #26319 by mwm
That LemonRX will bind with either DSM2 or DSMX, you'll have to select which on your Tx.
Gut reaction: use the lemonRx unless you need the extra channels. It weighs less, the satellite should allow for better reception, and it's not clear the walkera has a failsafe feature.
The Naza should come with instructions on setting up your Tx. If you're having trouble with that, tell us which parts you're having problems with.
11 Nov 2014 04:02 #26348 by PLaYeN2174
Replied by PLaYeN2174 on topic quanum venture with devo 10 lemon rx ppm
Any updates? I"ve got a Venture also, but I'm using a naza m v2... it seems to not want to start.... I have two rx 1002 and 703a, bot seem to have same issue... anyone with advise?
Time to create page: 0.034 seconds
