Dlg glider model config
- Teemu147
01 Feb 2015 09:26 - 01 Feb 2015 09:59 #28316
by Teemu147
Dlg glider model config was created by Teemu147
Hello! can some one please help me to do model config to my dlg glider based to this video:Flight modes to fmod switch and if its possible chance that launch switch to same as "throttle" max launch switch is.
Last edit: 01 Feb 2015 09:59 by Teemu147.
- Teemu147
01 Feb 2015 17:41 - 14 Feb 2015 08:08 #28330
by Teemu147
Replied by Teemu147 on topic Dlg glider model config
No need anymore, got it working on my own
Last edit: 14 Feb 2015 08:08 by Teemu147.
- KArlk.
03 May 2017 11:33 #61957
by KArlk.
Replied by KArlk. on topic Dlg glider model config
I know this is an old thread, but could you upload your config? There aren't many DLG configs around here, so it would be nice to have a starting point
- RoGuE_StreaK
04 May 2017 00:31 #61975
by RoGuE_StreaK
Replied by RoGuE_StreaK on topic Dlg glider model config
Here's a thread / attachment
that might help, my DLG setup, doesn't have presets for speed/cruise etc. but should give a good starting point. Just need to add a few more Pages to each aileron channel (and maybe elevator) and assign fixed values to a certain switch position for each Page.
eg. switch of Mix0, mux "add", a fixed value of let's say -20, then on the next Page have switch Mix1, mux "add", fixed value of +60, etc. But one of these switch positions will be an "add" of 0, so it doesn't affect the output. Get it right on one aileron, then copy across to the other one, likely changing some positived to negatives as the servo will likely be going in the opposite direction.
Even though each subsequent Page uses "add", it really combines to make an "or" system as your switch is only ever in one of those positions. (it adds 0, OR it adds -20, OR it adds +60, etc).
Time to create page: 0.034 seconds
Model Configs
Model Requests
- Dlg glider model config
