Model for Blade Nano QX 3D
05 Feb 2015 07:54 - 05 Feb 2015 07:55 #28406 by sv650s
Model for Blade Nano QX 3D was created by sv650s
i search if someone have already made a config model for the new Blade Nano QX 3D
Blade nano QX 3D
thanks for your help
Last edit: 05 Feb 2015 07:55 by sv650s.
05 Feb 2015 11:34 #28410 by Joshua
Replied by Joshua on topic Model for Blade Nano QX 3D
If i get my Nano QX 3D, i will post a config file very soon. :P
05 Feb 2015 11:40 #28411 by sv650s
Replied by sv650s on topic Model for Blade Nano QX 3D
ok, thanks very much
i hope you can post complete config file for use all possibility of this quad
best regards
22 Feb 2015 17:01 #29001 by sourdiesel
Replied by sourdiesel on topic Model for Blade Nano QX 3D
Does anyone have a working ini file for the nqx 3d? The 180qx INI I modified to work has some bugs.
22 Feb 2015 18:31 #29006 by Joshua
i am still waiting for my preordert Nano QX 3D. :(
22 Feb 2015 20:38 #29018 by sourdiesel
OK ! I hope you get it soon ! The problem I'm having is the throttle cut doesn't work while I'm in 3d mode, the mode where you need throttle cut the most. It works while on the ground but once in air it doesn't!
23 Feb 2015 02:08 - 23 Feb 2015 03:06 #29026 by Joe
Replied by Joe on topic Model for Blade Nano QX 3D
Sorry for my bad english!
Create from another template. I do not know if it is optimized but it works.
The throttle cut work only in 3D mode, in fmode0 used to do 360 flip, and in fmode1 used to do 180 flip.[/u]
The throttle cut (3D mode) and the flip work with the channel 6 on the Nano QX 3D.
RUDD D/R switch = The throttle cut/Flip fonction
The fonction is enabled in any direction on the switch (normally not, but I programmed to do this.)
--> pos 0 to pos 1 = enabled
--> pos 1 to pos 0 = enabled
If fmode0 + RUDD switch = 360 flip enabled
If fmode1 + RUDD switch = 180 flip enabled
If fmode2 + RUDD switch = Throttle cut enabled
ELEV D/R switch = Dual rate Ail and ELE
Pos 0 = 100%
Pos 1 = 70%
Fmode swich =
Pos 0 = Stability mode (360 flip)
Pos 1 = 3D agility mode (180 flip)
Pos 2 = EVO mode (3D mode)
The AIL and ELE EXPO is 30%
Last edit: 23 Feb 2015 03:06 by Joe.
28 Feb 2015 11:25 #29204 by Joshua
My Nano QX 3D arrived today. :)
Here my color icon.
ciao, Bernd
06 Mar 2015 18:38 #29412 by sv650s
with your model, witch switch make fly the nano qx 3D on the back ?
06 Mar 2015 19:48 #29413 by Joshua
You have to toggle the RUDD D/R switch and after that roll or nick. (Ail or Ele)
13 May 2015 15:16 - 16 May 2015 18:33 #32493 by 30secs
Replied by 30secs on topic Model for Blade Nano QX 3D
Does anyone have or can help create a buttoned up model config? mwm?
Here's as far as i can go..
channel 5 -- mode switch (100/0/-100) beginner/inter/3D manual (used mwm's trick)
Channel 6 - used trim up trigger to enable flip
Need:
Throttle hold -- not sure if horizon/blade has safety val outside the -100/100?
for modes 1 and 2 -- -100 is the safe val
mode 3 3D -- 0 is when trottle is off (??)
Also, when in 3D mode/manual, the ail/ele/rud get reversed on flip so missing an adjustment for that as well
Thank youooo
Last edit: 16 May 2015 18:33 by 30secs.
05 Aug 2015 19:44 #36591 by Syncro
Replied by Syncro on topic Model for Blade Nano QX 3D
Hi all.
Fairly new to quads and very new to my Devo 7e.
As the 7e has less switches is it possible to configure a Nano 3d to this transmitter?
Thanks.
04 Oct 2015 02:26 #38410 by cesone
Replied by cesone on topic Model for Blade Nano QX 3D
I'm also looking for one for the devo 7e
I found one that a guy named rcflyair (i think) from another forum. He made the hold switch to the left to change to beginner mode and 3d mode only..... he didn't program the trigger. so the right switch is throttle hold.
i rather have the right switch be the trigger so i can do flips
I added the .ini. Maybe someone can modify it.... make it have all 3 modes and the trigger
Time to create page: 0.285 seconds
