Blade Nano QX
21 Mar 2015 22:54 #30015 by Skysurfer
Blade Nano QX was created by Skysurfer
I have a Nano Qx any configs?
24 Mar 2015 23:12 #30214 by gordonzo
Replied by gordonzo on topic Blade Nano QX
I have one for Devo 10.
Different fly for different guy.
06 Apr 2015 22:15 #30854 by Skysurfer
Replied by Skysurfer on topic Blade Nano QX
Can you share it please?
07 Apr 2015 01:53 #30859 by mwm
Replied by mwm on topic Blade Nano QX
Here's mine for the Devo6S.
Flight mode switches on the EXT button.
You'll need to fix the switches on most other Tx's: dual rates is on the D/R switch, sticky throttle hold on the GEAR switch, and timer reset on the MIX switch. Fix them in the main page toggle configs as well.
Icon is from the icons section of the forums.
07 Apr 2015 05:10 #30865 by Skysurfer
mwm much thanks but I am using a DEVO 10.
15 May 2015 22:35 #32633 by gordonzo
@Skysurfer - did you get your Devo 10 config file?
All my ini files can be downloaded here:
lonagord.wix.com/bigglittleo-1#!devo-10---deviation-40/c24ax
g
16 May 2015 03:03 #32638 by mwm
The deviation files can be shared between different transmitter models. You just need to check/fix the switches.
Time to create page: 0.893 seconds
