QAV/ZMR 250 Model file
07 Apr 2015 23:29 #30896 by ccsteeher
QAV/ZMR 250 Model file was created by ccsteeher
Can someone provide me their basic QAV/ZMR250 model template for Deviated Devo 10? Having some issues getting mine sorted out properly. Thank you!
10 Apr 2015 02:01 #30967 by Cereal_Killer
Replied by Cereal_Killer on topic QAV/ZMR 250 Model file
What FC and RX are you running?
11 Apr 2015 13:52 #31038 by syncronized77
Replied by syncronized77 on topic QAV/ZMR 250 Model file
ccsteeher wrote: Can someone provide me their basic QAV/ZMR250 model template for Deviated Devo 10? Having some issues getting mine sorted out properly. Thank you!
I'm kind of in the same boat as you! Are you running a Naze32?
27 Jun 2015 19:43 #34761 by brew99
Replied by brew99 on topic QAV/ZMR 250 Model file
I'm looking for something similar also. Using Flip32+, Orange 615x in PPM (TAERAux1Aux2) and Devo7e with 3x2 switch mod
27 Jun 2015 22:03 - 27 Jun 2015 22:14 #34771 by aMax
Replied by aMax on topic QAV/ZMR 250 Model file
Build your own, just simple plane setup.
Aileron and Rudder are reversed. All simple or if you like with expo.
CH 5 and CH6 have to be setup complex since they are the switches.
The rest is set at the FC setup.
Extend your own stick range from 1000 to 2000 and use subtrim for neutral at nearly 1500 for
AIL, ELV and RUD. Throttle stays at normal.
I said nearly, because the pots are not that good on the 7e and you will not hit the middle at 1500
...1497 or 1501 may be the constant neutral. This has to be set at the FC setup for RC middle.
My gear: flip32+ & CC3D> RX615X / PPM/ Storm S603/PPM > 3x2 sw
Last edit: 27 Jun 2015 22:14 by aMax.
15 Jul 2015 06:50 #35459 by Scav
Replied by Scav on topic QAV/ZMR 250 Model file
Anyone with a File for CC3D with DSM2 (LemonRX) Setting?
Thanks in advance
Time to create page: 0.121 seconds
