Model.ini for Tarantula X6 (V2x2), V686G (FlySky)?
16 May 2015 20:56 #32661 by WiKDMONKY
My life will be complete if someone can point me in the right direction to get my quads working with my shiny new Devo 7e with A7105 and nrf24l01 modules installed. I already was able to find an ini for my Hubsan X4 H107's.
Thanks in advance!
16 May 2015 23:55 #32672 by mbk17
I am also looking for an ini for the X6 all I can tell you is that it uses the V202 protocol. If you end up getting anything to work, let me know!
21 May 2015 05:27 #32813 by mbk17
Somehow I did not see the ini file posted on SeByDocKy's RCGroups. The download link is here: www.rcgroups.com/forums/showatt.php?atta...7754012&d=1428600261 I had to remove the "Fixed ID" section on the ini to get it to bind.
However, once bound, my LEDs turn off and I have no idea why. Anyone know a solution?
21 May 2015 06:39 #32814 by SeByDocKy
mbk17 wrote: Somehow I did not see the ini file posted on SeByDocKy's RCGroups. The download link is here: www.rcgroups.com/forums/showatt.php?atta...7754012&d=1428600261 I had to remove the "Fixed ID" section on the ini to get it to bind.
Maybe it was default pressed value. Press right once the yaw trimming button
21 May 2015 18:29 - 21 May 2015 18:35 #32838 by mbk17
That worked perfectly thanks a lot Seb, a pleasure to have a response straight from you. What is the significance of the fixed ID by the way? And where do you find it for each model?
Last edit: 21 May 2015 18:35 by mbk17.
09 Jun 2015 02:24 #33677 by raduque
I'm having a small problem with this ini. It seems that when trying to fly, only my CCW motors spin - my CW motors don't spin until I hit ~70% throttle, and when it does lift off, it just yaws left.
I haven't made any changes to the ini, and the quad flies fine with the stock TX. Anybody help?
09 Jun 2015 02:32 #33678 by willpc
How did you get the husban working with your devo 7e? Just picked one up today for a steal. Thanks!
09 Jun 2015 02:39 #33679 by raduque
im not flying any hubsans with my devo yet. Im looking for help troubleshooting my jjrc Tarantula x6
16 Jul 2015 05:52 #35508 by Csnop
Hi everyone
I have a Devo 10 and I'm looking for the Model.ini for WLtoys V686G last version receiver.
Did someone work on it ?
18 Oct 2015 00:10 #38996 by Trailer Park Tony Stark
Replied by Trailer Park Tony Stark on topic Model.ini for Tarantula X6 (V2x2), V686G (FlySky)?
Just got done with a test flight using my Tarantula X6, Devo 7E (modded), and SeByDocKy's ini file for the V2x2 protocol. Wow! What a difference from the stock tx. Even more fun to fly!
Many thanks to you, SeByDocKy. The file works very well!
21 Feb 2016 00:18 #43390 by jimw1956
I'm using this ini on a devo 7e, of course I only have the first two flight modes.
When I bind to the stock transmitter, the lights on the quad light solid, when I bind with the 7e and this ini, they flash on and off slowly...it appears to fly correctly...is this normal or is something not completely binding correctly?
Time to create page: 0.053 seconds
