Belt CP and Devo10
07 Jun 2015 07:59 #33571 by easyacid
Belt CP and Devo10 was created by easyacid
Hi folkes,
I am looking for a devo10 configfile for my Belt cp. Do someone have one?
Thanks a lot.
Greetings Easy.
12 Feb 2016 09:07 #43030 by easyacid
Replied by easyacid on topic Belt CP and Devo10
Hi.
I have to push my question.
Greetings
12 Feb 2016 12:48 - 12 Feb 2016 12:49 #43033 by Thomas.Heiss
Replied by Thomas.Heiss on topic Belt CP and Devo10
For a paddle you should use the 6CH heli template and setup 120 degree CCPM mixing.
You really need to individually adjust the cyclic and collective numbers in CCPM according to your mechnical requirements and pitch gauge meassuring (max pitch, no bindings).
You also need to individually set servo travel min/max on all three cyclic channels to level the swashplate when on min/max collective pitch.
A ready model ini simply makes no sense IMHO for a flybar heli.
There are multiple heli / flybar / CCPM mixing threads on this forum (e.g switching CYclic1/Cyclic2 mixing channels).
Please try to learn to setup a heli correctly within DeviationTX step by step.
For a first start you can try the simple heli mixer GUI which is like Spektrum DX8 airware and has 0815 menus.
You can later convert the heli model to the advanced mixer GUI for more fine tuning / tweaking (e.g gyro gain on knob).
Reading thru Spektrum DX8 Horizon / Blade documentation helps a little bit too to get a basic understanding.
Have you already checked DeviationTX PDF manual and online html manual?
Thomas
Last edit: 12 Feb 2016 12:49 by Thomas.Heiss.
Time to create page: 0.159 seconds
