XK X350 3D dancer
21 Oct 2015 15:44 #39102 by cedric
21 Oct 2015 17:20 #39103 by TomPeer
Replied by TomPeer on topic XK X350 3D dancer
Futaba S-FHSS
14 Jan 2017 09:00 #57923 by mayuwei
Replied by mayuwei on topic yoshop.com/item/xk-x35
This one is a little bit expensive.
And XK Stunt X350 Quadcopter is a professional RC simulator, the patent of appearance design make it looks smooth and unique. With professional technology support, the protocol compatible with FUTABA S - FHSS. And, you can transform between 3D and 6G mode conveniently according to you need.
Protocol compatible with FUTABA S - FHSS: Professional technology support for its control.
Appearance design patent: The unique body appearance design is scientifically designed for taking and maintain conveniently. The patent number is 201530002080.
With 3D aerobatic flights function: Makes you enjoy more fun with the quadcopter like 3D Inverted Flight.Bi-directional brusheless motor and quick response ESC can help you to do extreme 3D aerobatic flights.
14 Jan 2017 18:28 #57941 by Quadman
Replied by Quadman on topic yoshop.com/item/xk-x35
This one is for the XK X100 same flight characteristics 6G 3D inverted, should work, if X 350 has bind button?
www.deviationtx.com/forum/model-configs/...ig-for-7e-and-d10-d8
Time to create page: 0.100 seconds
