[Request] Devo 7E Floureon H101
21 Jan 2016 12:28 #42034 by Scav
[Request] Devo 7E Floureon H101 was created by Scav
Hi Guy's,
I'm looking for a Modelfile for this Quad.
Following Features:
- Headless Mode
- Inverted Flight Mode
- Flips
- One Key Return
I'm using a Devo 7E (+ 3 Way Switchmod) and checked with Bayang Protocol and a H8 Mini Modelfile.
Throttle works fine, but all other axes are very slow. Also all of the Switches changing nothing.
Would appreciate any response.
27 Jan 2016 06:36 #42268 by slo_rider
Replied by slo_rider on topic [Request] Devo 7E Floureon H101
Here's what I've found:
(Banyang protocol)
Channel 5: inverted
Channel 6: flip
Channel 9: headless
Channel 10: RTH
Flip does not seem to work as a momentary button, so you have to toggle it.
Here's my config:
name=Floureon
mixermode=Advanced
type=multi
[radio]
protocol=Bayang
num_channels=11
tx_power=150mW
[channel1]
template=simple
[mixer]
src=AIL
dest=Ch1
[channel2]
template=simple
[mixer]
src=ELE
dest=Ch2
[channel3]
safetysw=FMODE1
safetyval=-150
template=simple
[mixer]
src=THR
dest=Ch3
[channel4]
template=simple
[mixer]
src=RUD
dest=Ch4
[channel5]
template=simple
[mixer]
src=Virt1
dest=Ch5
curvetype=expo
points=0,0
[channel6]
template=simple
[mixer]
src=Virt2
dest=Ch6
curvetype=expo
points=0,0
[channel9]
template=simple
[mixer]
src=HOLD1
dest=Ch9
curvetype=expo
points=0,0
[channel10]
template=simple
[mixer]
src=Virt3
dest=Ch10
curvetype=expo
points=0,0
[trim1]
src=Virt1
pos=TRIMLV+
neg=TRIMLV-
step=193
value=-100,0,0
[trim2]
src=RIGHT_V
pos=TRIMRV+
neg=TRIMRV-
value=12,0,0
[trim3]
src=LEFT_H
pos=TRIMLH+
neg=TRIMLH-
value=5,0,0
[trim4]
src=RIGHT_H
pos=TRIMRH+
neg=TRIMRH-
value=-99,0,0
[trim5]
src=Virt2
pos=TRIMLV-
step=192
value=-100,0,0
[timer2]
type=countdown
time=10
[safety]
Auto=min
[gui-128x64]
V-trim=59,10,1
H-trim=5,59,3
V-trim=65,10,2
H-trim=74,59,4
Small-box=2,22,Ch3
Small-box=2,31,Timer1
Small-box=2,40,Timer2
Model=75,20
Battery=102,1
Toggle=4,10,0,3,0,None
Toggle=13,10,0,5,0,None
Toggle=22,10,0,4,0,None
Toggle=31,10,0,0,0,None
Toggle=40,10,0,0,0,None
TxPower=102,7
quickpage1=Telemetry monitor
27 Jan 2016 11:51 #42272 by Deal57
Replied by Deal57 on topic [Request] Devo 7E Floureon H101
Your model.ini file seems to be missing the entries defining the virtual channels. Your buttons probably don't work, right?
I think you just need to set Virt1, Virt2 and Virt3 up as simple mixer types with min/max curve using the transmitter GUI. Hmmm... You also need to add Virt3 to a trim button, I think. Since you're able to fly with this one, be sure to make backups before you make changes!
27 Jan 2016 17:04 #42278 by slo_rider
Deal57 wrote: Your model.ini file seems to be missing the entries defining the virtual channels. Your buttons probably don't work, right?
Sorry, I should have explained my config more, it was late when I posted this ;)
My config is pretty standard, I've only mapped the channels for flip, inverted and headless. The missing entry you're seeing is channel10, RTH, which I have set to Virt3 under mixer settings, but it is not defined as a trim. If you want RTH, just define it under trims on the TX gui, source Virt3.
Flip = throttle trim down (TrimLV-) toggle button
Inverted = throttle trim up (TrimLV+) momentary button
Headless = Hold1
Throttle safety = Fmod1
28 Jan 2016 08:05 #42308 by slo_rider
I did some more testing and I was incorrect about flip needing to be a toggle, it works normally as a momentary switch. I assigned it to a different button and it worked. For some reason w/ my config listed above, when pressing TrimLV-, it was sending to both channel 5 and 6, instead of just 6 for flip. I noticed this by editing my main page config to toggle those channels on the display. Not sure why it's sending a channel 5 signal when pressing either TrimLV-/+. I changed my flip button to EXT under the Trims menu, now it works as a momentary.
29 Jan 2016 07:43 - 29 Jan 2016 21:33 #42358 by Scav
Replied by Scav on topic [Request] Devo 7E Floureon H101
Hi slo_rider,
many thanks for that :)
Got my problems fixed, it was required to upgrade to the latest Nightly to get Inverted mode to work.
remapped the buttons.
Using Hold 1 as Throttle enabled
SWA1 - Flip
SWA2 - Inverted
SWB2 - RTH
FMOD1 - Headless
Thanks for pointing me in the right direction.
Last edit: 29 Jan 2016 21:33 by Scav.
02 Mar 2016 07:47 - 05 Mar 2016 06:58 #43975 by jboehm
Replied by jboehm on topic [Request] Devo 7E Floureon H101
Can someone post a model config file with invert working? I have everything else but for the life of me I can't seem to get invert to work.
UPDATE: Upgrading to the latest Nightly Build fixed my issue.
Last edit: 05 Mar 2016 06:58 by jboehm.
13 Oct 2016 15:14 - 13 Oct 2016 15:33 #54885 by joelones
Replied by joelones on topic [Request] Devo 7E Floureon H101
I just installed the NRF24L01 module and I was able to bind to the H101 by selecting bayang but the quad yaws like crazy. Flys fine with the stock controller.
Any help for a noob to fix this?
I tried to copy slo_rider's ini to the 7E but it does not bind for some reason. LEDs blink fast. Perhaps I'm doing something wrong.
Using deviation-devo7e-v5.0.0-bff7c9c
Help?
Last edit: 13 Oct 2016 15:33 by joelones.
13 Oct 2016 16:00 #54889 by FDR
Replied by FDR on topic [Request] Devo 7E Floureon H101
I fly both my H101 and H8 mini with the same H8 mini config, so Bayang works fine with the H101...
Time to create page: 0.076 seconds
