Blade 300CFx and Devo10 ini file
- yrjou
18 Feb 2016 09:45 #43234
by yrjou
Blade 300CFx and Devo10 ini file was created by yrjou
I got a Blade 300Cfx and would like to connect with Devo10.
Did anyone has Devo10 with Blade 300cfx ini file can share to me?
Or, can I just use my 180Cfx ini file for Blase 300Cfx?
thanks for your help.
- Thomas.Heiss
18 Feb 2016 12:26 #43240
by Thomas.Heiss
Replied by Thomas.Heiss on topic Blade 300CFx and Devo10 ini file
Sure, both are FBL.
So there is not really that much to be setup / programmed within DeviationTX.
You just need to adjust DualRate, Expo, pitch- and throttle (fixed) curves....
You do NOT even have to adjust pitch servo travel subtrim and scale+ and scale- values for 0-degree and equal +- 12 degree max pitch within DeviationTX. Leave it to 0 and 100%.
You just do that in your FBL (MicroBeast) system (this is not a NanoCPX where you have to use that workarounds).
Thomas
Thomas
- yrjou
19 Feb 2016 01:57 #43272
by yrjou
Replied by yrjou on topic Blade 300CFx and Devo10 ini file
OK, thanks for your help.
I will try this weekend.
thanks again
thanks again
Time to create page: 0.119 seconds
Model Configs
Model Requests
- Blade 300CFx and Devo10 ini file
