Help setting up flaperons on FT3D with DEVO7E
27 Mar 2016 14:51 - 27 Mar 2016 14:53 #45269 by Siezed
Hello, i was wondering if someone could help me set up flaperons correctly on a 6ch receiver (5ch used) and devo 7e with my freshly built flite test FT3D? I have tried a template with flaperons included but something weird is happening, it seems when i use full right aileron with flaps down, the left aileron does not move down, but when i use full left aileron with flaps down, i get more down travel from the right aileron. Its very hard to explain but its as if one flaperon is bottomed out when i activate flaps, and the other behaves normally. Its set up how i want, except one aileron seems to not be traveling fully down with flaps extended, however if someone can point me to any plane config with 4 servos and flaperons that may be all i need as well. Also i suspect it may have something to do with the fact im using a devo 7e with stock switches, and this template has 3drs? Not sure still figuring this all out.
The template i'm using is here; www.deviationtx.com/forum/model-configs/...perons-and-3-dr#5379
And just to make it easier heres the actual text copied, any help would be appreciated, thanks!;
name=PLANEFALPERONS
type=plane
[radio]
protocol=DEVO
num_channels=10
tx_power=100mW
[protocol_opts]
Telemetry=On
[channel1]
scalar-=0
template=expo_dr
[mixer]
src=ELE
dest=Ch1
scalar=50
[mixer]
src=ELE
dest=Ch1
switch=FMODE1
scalar=80
[mixer]
src=ELE
dest=Ch1
switch=FMODE2
[channel2]
scalar-=0
template=expo_dr
[mixer]
src=Virt1
dest=Ch2
scalar=60
[mixer]
src=Virt1
dest=Ch2
switch=FMODE1
scalar=80
[mixer]
src=Virt1
dest=Ch2
switch=FMODE2
[channel3]
safetysw=RUD DR
safetyval=-100
scalar-=0
template=simple
[mixer]
src=THR
dest=Ch3
[channel4]
reverse=1
scalar-=0
template=expo_dr
[mixer]
src=RUD
dest=Ch4
scalar=60
[mixer]
src=RUD
dest=Ch4
switch=FMODE1
scalar=80
[mixer]
src=RUD
dest=Ch4
switch=FMODE2
[channel5]
scalar-=0
template=expo_dr
[mixer]
src=GEAR
dest=Ch5
[channel6]
reverse=1
scalar-=0
template=expo_dr
[mixer]
src=Virt2
dest=Ch6
scalar=60
usetrim=0
curvetype=expo
points=0,0
[mixer]
src=Virt2
dest=Ch6
switch=FMODE1
scalar=80
usetrim=0
curvetype=expo
points=0,0
[mixer]
src=Virt2
dest=Ch6
switch=FMODE2
usetrim=0
curvetype=expo
points=0,0
[virtchan1]
template=complex
[mixer]
src=AIL
dest=Virt1
switch=MIX0
usetrim=0
curvetype=expo
points=0,0
[mixer]
src=AIL
dest=Virt1
switch=MIX1
offset=60
usetrim=0
curvetype=expo
points=0,0
[mixer]
src=AIL
dest=Virt1
switch=MIX2
offset=90
usetrim=0
curvetype=expo
points=0,0
[virtchan2]
template=complex
[mixer]
src=!AIL
dest=Virt2
switch=MIX0
usetrim=0
curvetype=expo
points=0,0
[mixer]
src=!AIL
dest=Virt2
switch=MIX1
offset=70
usetrim=0
curvetype=expo
points=0,0
[mixer]
src=!AIL
dest=Virt2
switch=MIX2
offset=90
usetrim=0
curvetype=expo
points=0,0
[trim1]
src=LEFT_V
pos=TRIMLV+
neg=TRIMLV-
[trim2]
src=RIGHT_V
pos=TRIMRV+
neg=TRIMRV-
[trim3]
src=LEFT_H
pos=TRIMLH+
neg=TRIMLH-
[trim4]
src=RIGHT_H
pos=TRIMRH+
neg=TRIMRH-
[timer1]
src=THR
[timer2]
src=ELE
[safety]
Ch3=min
[gui-qvga]
trim=4out
barsize=half
box1=Ch3
box2=Timer1
box3=Timer2
bar1=Ch1
bar2=Ch2
bar3=Ch3
bar4=Ch4
toggle1=FMODE0
tglico1=1
toggle2=FMODE1
toggle3=FMODE2
tglico3=2
toggle4=RUD DR
tglico4=4
Last edit: 27 Mar 2016 14:53 by Siezed.
28 Mar 2016 20:06 #45350 by Siezed
Ok I figured out the problem I believe, my transmitter was set up as min and max -150 and +150 scale, so changing it to 100 seemed to fix this on a simple flaperon mix, ill have to try it on this specific config as well.
Time to create page: 0.208 seconds
