- Model Requests
- Hobbyking DLG mini Pro/ SAL without RUD for DEVO7E
- Gutflieger
10 Apr 2016 09:11 - 10 Apr 2016 09:41 #46251
by Gutflieger
Hobbyking DLG mini Pro/ SAL without RUD for DEVO7E was created by Gutflieger
Hello, I am quite new to fixed wings and I wanted to start with a Side Arm Laucher / Discus Lauch Glider Plane from Hobbyking. It is this model:
www.hobbyking.com/hobbyking/store/__6138...rple_990mm_PNF_.html
I was wondering if someone could provide me with an ini file for I am totally lost in Mixers, Pages and mux... HELP anyone?
I am using a Devo 7E.
Thanks in advance!
Thanks in advance!
Last edit: 10 Apr 2016 09:41 by Gutflieger.
- Ryou
10 Apr 2016 10:17 - 10 Apr 2016 10:19 #46253
by Ryou
Replied by Ryou on topic Hobbyking DLG mini Pro/ SAL without RUD for DEVO7E
I'm not good at English.
For JR ARFLOW 4ch-DLG setting.
2 of 3p switch is being added.
SW A0 launch
SW A1 Norm (camber can be changed by SW B.)
SW A2 Landing
TH-Trim camber Adjustment.
R+,L- Key Flap adjustment
CH1,CH2
AIL
CH3 ELE
CH4 RUD
SW A0 launch
SW A2 Landing
CH1,CH2
AIL
CH3 ELE
CH4 RUD
Last edit: 10 Apr 2016 10:19 by Ryou.
- blackmoon
10 Apr 2016 16:12 - 10 Apr 2016 16:12 #46270
by blackmoon
Replied by blackmoon on topic Hobbyking DLG mini Pro/ SAL without RUD for DEVO7E
Hi Ryou,
Is this some kind of flaps->elevator mixing ?
Thx.
Thx.
[virtchan4]
name=ELE-S
template=complex
[mixer]
src=AIL
dest=Virt4
scalar=0
usetrim=0
curvetype=fixed
[mixer]
src=AIL
dest=Virt4
switch=SW A2
scalar=18
usetrim=0
curvetype=fixed
[mixer]
src=AIL
dest=Virt4
scalar=10
usetrim=0
muxtype=delay
curvetype=fixed
Last edit: 10 Apr 2016 16:12 by blackmoon.
- Ryou
11 Apr 2016 10:15 #46309
by Ryou
Yes.
elevator mixing. AirBrake when the elevator down.
SW-A is in the flight mode, you can adjust the elevator-trim in each flight mode.
Flap amount of left and right AIL can also be adjusted for each flight mode.
I am sorry in poor English.
- Gutflieger
11 Apr 2016 20:11 #46322
by Gutflieger
Replied by Gutflieger on topic Hobbyking DLG mini Pro/ SAL without RUD for DEVO7E
Hi Ryou,
thanks for your help! I am confused: I am using Mode2, THR is on the left stick , ELEV is on th right stick.
So when i use the right stick up and down, ELEV is working fine. If I move it left to right, only one Flap is moving up and down. For the other flap I have to move the left stick right to le
QUestion: What do I have to do to make both flaps move with only the right stick? So if I move the right stick to the right, one flap goes up and the other goes down? IS this called "add" or "Mux"?
Sorry for being not so advanced in programming....
- Ryou
12 Apr 2016 00:31 #46335
by Ryou
I have been using the MODE1.
SW-A is the left shoulder, SW-B has been added to the right shoulder.
THR stick is not used. THR-TRIM is used in camber adjustment.
FLAP amount you may want to change the fixed value of the virtual Flap-CH if you want to adjust the THR stick in THR. (To operate in the lower half use the 3P curve?)
basic operation
SW-A0 Launch (AIL rises only left and right a little)
Straight to adjust the ELE-TRIM and AIL-TRIM to rise.
SW-A1 Normal flight.
In SW-B switch Cruise, Speed, the Thermal (each camber amount is adjusted by the THR-TRIM)
SW-A2 Land.
Left and right aileron drops below. ELE also down is MIX.
I am set to make it easier to operate using the Mode1 transmitter in the right-handed.
What can not be good or advice if in Mode2.
It is difficult not good explanatory English
basic operation
SW-A2 Land.
- Gutflieger
12 Apr 2016 21:30 #46383
by Gutflieger
THanks for that explanation. This is quite a complex model which I find very nice! I am currently reading all the basics about Deviation such as
rc.mired.org/p/writing-deviationtx-model.html
or
www.rcgroups.com/forums/showthread.php?t...+7E+ini#post27636685
. I see that as a beginner there is a lot of reading to do for me. so thanks for being so patient with me. I will read more and than be hopefully able to ask better questions...
- Gutflieger
13 Apr 2016 19:45 #46444
by Gutflieger
So I did a lot of reading and watching videos.(such as ) and now I got my DLG working! Yeah!
I just wondered if you, Ryou, could tell me how to add some functionality to THR, such as using AIL, RUD and ELE as breaking flaps such as if I move down th THR both flaps of the wings will com e down and the ELE also. Does that make any sense?
I guess I will start flying the model and find out. But If you have an idea to add to my thoughts I would appreciate this! Thanks for your help so far.
- Ryou
15 Apr 2016 12:40 #46561
by Ryou
English can not be well understood.
Will you have to adjust the air brake in THR?
It does not work make sure you attach the sample.
(Model44.ini)
State defeated the SW-A to the front.
Lowered to below the middle of the THR stick.
FLAP is get down in proportion, at the same time ELE down mix.
You can also switch the flight mode at the position of the THR stick but, Deviation does not work as expected because it is not complete. The DLG-ELF (2ch) has switched in the THR stick. (Model41.ini)
For reference only setting.
(Model44.ini)
- Model Requests
Time to create page: 0.152 seconds
Model Configs
Model Requests
