- Model Requests
- i need help 6 channel r615x cc3d betaflight Devo 7
- kaligola
23 May 2016 21:36 #49088
by kaligola
i need help 6 channel r615x cc3d betaflight Devo 7 was created by kaligola
need some help to make model for this build, first time i use devo 7e
in cleanflight receiver settings i see channel not centered and throttle would not arm so ectended range but need to make fmod and hol to combine flight modes and dual rates or led (one of this two) all in 6 channels
transmitter has only renge mod not switches mode
here is what i did until messed up all
name=zmr160
mixermode=Advanced
type=multi
[radio]
protocol=DSMX
num_channels=6
fixed_id=123369
tx_power=150mW
[channel1]
scalar=120
scalar-=120
subtrim=5
template=simple
[mixer]
src=THR
dest=Ch1
[channel2]
reverse=1
scalar=110
scalar-=110
subtrim=10
template=simple
[mixer]
src=AIL
dest=Ch2
[channel3]
template=simple
[mixer]
src=ELE
dest=Ch3
[channel4]
reverse=1
template=simple
[mixer]
src=RUD
dest=Ch4
scalar=115
[channel5]
template=simple
[mixer]
src=HOLD0
dest=Ch5
curvetype=expo
points=0,0
[channel6]
safetysw=!FMODE0
template=complex
[mixer]
src=FMODE0
dest=Ch6
switch=FMODE1
curvetype=expo
points=0,0
[ppm-in]
mode=stick
num_channels=1
switch=None
centerpw=1500
deltapw=400
map1=THR
map2=AIL
map3=ELE
map4=RUD
map5=None
[trim1]
src=LEFT_V
pos=TRIMLV+
neg=TRIMLV-
[trim2]
src=RIGHT_V
pos=TRIMRV+
neg=TRIMRV-
[trim3]
src=LEFT_H
pos=TRIMLH+
neg=TRIMLH-
[trim4]
src=RIGHT_H
pos=TRIMRH+
neg=TRIMRH-
[timer2]
type=countdown
time=10
[safety]
Auto=min
[gui-128x64]
V-trim=59,10,1
H-trim=5,59,3
V-trim=65,10,2
H-trim=74,59,4
Small-box=2,22,Ch1
Small-box=2,31,Timer1
Small-box=2,40,Timer2
Model=75,20
Battery=102,1
Toggle=4,10,0,3,0,None
Toggle=13,10,0,5,0,None
Toggle=22,10,0,4,0,None
Toggle=31,10,0,0,0,None
Toggle=40,10,0,0,0,None
TxPower=102,7
quickpage1=Telemetry monitor
telemetry do not need...
name=zmr160
mixermode=Advanced
type=multi
[radio]
protocol=DSMX
num_channels=6
fixed_id=123369
tx_power=150mW
[channel1]
scalar=120
scalar-=120
subtrim=5
template=simple
[mixer]
src=THR
dest=Ch1
[channel2]
reverse=1
scalar=110
scalar-=110
subtrim=10
template=simple
[mixer]
src=AIL
dest=Ch2
[channel3]
template=simple
[mixer]
src=ELE
dest=Ch3
[channel4]
reverse=1
template=simple
[mixer]
src=RUD
dest=Ch4
scalar=115
[channel5]
template=simple
[mixer]
src=HOLD0
dest=Ch5
curvetype=expo
points=0,0
[channel6]
safetysw=!FMODE0
template=complex
[mixer]
src=FMODE0
dest=Ch6
switch=FMODE1
curvetype=expo
points=0,0
[ppm-in]
mode=stick
num_channels=1
switch=None
centerpw=1500
deltapw=400
map1=THR
map2=AIL
map3=ELE
map4=RUD
map5=None
[trim1]
src=LEFT_V
pos=TRIMLV+
neg=TRIMLV-
[trim2]
src=RIGHT_V
pos=TRIMRV+
neg=TRIMRV-
[trim3]
src=LEFT_H
pos=TRIMLH+
neg=TRIMLH-
[trim4]
src=RIGHT_H
pos=TRIMRH+
neg=TRIMRH-
[timer2]
type=countdown
time=10
[safety]
Auto=min
[gui-128x64]
V-trim=59,10,1
H-trim=5,59,3
V-trim=65,10,2
H-trim=74,59,4
Small-box=2,22,Ch1
Model=75,20
Battery=102,1
TxPower=102,7
- Model Requests
Time to create page: 0.191 seconds
Model Configs
Model Requests
