H8S 3D Mini for Devo7e
- Sicon
23 Jun 2016 08:51 #50976
by Sicon
H8S 3D Mini for Devo7e was created by Sicon
Hello! Any config for this new eachine H8S 3D mini model? I read it works with the bayang protocol (the same as the H8 mini), but what about the inverted fly functions? Is there a specific build for this?
Thank you!!
Thank you!!
- Josh69
23 Jun 2016 10:59 - 23 Jun 2016 11:00 #50980
by Josh69
Replied by Josh69 on topic H8S 3D Mini for Devo7e
Channel 5 is for inverted flying. Channel 6 for flip.
At work right now. But can upload my ini file later. Devo 10
Last edit: 23 Jun 2016 11:00 by Josh69.
- Josh69
23 Jun 2016 19:52 #51004
by Josh69
Model 4 are for DEVO 10 and Model 5 are for DEVO 7E. I don't have a DEVO 7E so I have not tried the ini file, but i think it will be good.
- Josh69
- Fernando
30 Aug 2016 20:53 #53298
by Fernando
Replied by Fernando on topic H8S 3D Mini for Devo7e
Hi there,
I have just bought H8-3D drone, I have tested the Devo10 model on my Devo 8 and it works, but I don't know how to access to advanced functions such us inverte flight or flips.
I have seen in protocol list that there is one H8-3D one but those models select Banyang protocol, Is it correct? Thanks!
- craigr
25 Mar 2017 15:54 - 25 Mar 2017 15:56 #60732
by craigr
Replied by craigr on topic H8S 3D Mini for Devo7e
Here is a config for the 7E. It uses HOLD for 360 flips and FMOD for 180 3D flips. Model29 is for regular 7E's and Model30 uses three position switch A to control three flight speeds.
I added "Mini Momentary On/Off Lockless Micro Push Button SPST Switchs" to my 7E across the HOLD and FMODE which work well for toy drones. If you don't have momentary switches across HOLD and FMODE you may want to remap those to trims or buttons. This is because if you leave HOLD or FMOD set to "1" the quad will flip every time you use AIL or ELE. You can use it as-is, but you have to toggle HOLD and FMODE a lot.
www.ebay.com/itm/322268842795
craigr
craigr
Last edit: 25 Mar 2017 15:56 by craigr.
- craigr
25 Mar 2017 15:58 #60733
by craigr
Thanks though,
craigr
Just wanted to say that this does not work on my 7E at all, which is why I created my own.Josh69 wrote: Model 4 are for DEVO 10 and Model 5 are for DEVO 7E. I don't have a DEVO 7E so I have not tried the ini file, but i think it will be good.
Thanks though,
craigr
Time to create page: 0.166 seconds
Model Configs
Model Requests
- H8S 3D Mini for Devo7e
