Default settings INI file for Furious 320 GPS
30 Jul 2016 19:44 #52297 by Blackrazid
So i did the misstake and going in and installing the devation 5.0 on my devo 10 transmitter.
I wanted to have the 100mw transmission to assure quality in signal (less disturbance)
Problem is that i forgot to back up my settings for the Furious 320 that i had uploaded from walkeraforums, (its a bin file) and DeviationTX uses ini files i am in big trouple.
Does any1 have that? and can help a fellow furious flyer out?
Stupid question:Cant see automatic ID assignement working in 5.0 ? (I am probably missing something stupid :) )
Any help is appreciated.
30 Jul 2016 20:16 #52298 by FDR
You can have auto binding if you clear the default fixed id.
BTW you can install back the Walkera devention fw, and your model configs will be there untouched, however the values might differ in deviation not to mention the whole programming...
30 Jul 2016 21:25 #52301 by Blackrazid
Replied by Blackrazid on topic Default settings INI file for Furious 320 GPS
Ye i went back to Walkeras FW.
Since i totally suck at the programming part.
But i would really want to get the FW from DeviationTX (fw 5.0) with possibitlty to override the EU regulated emitter power
So i am hoping for some1 out there to have a 320 Ini file to share:)
Time to create page: 0.495 seconds
