can you help me with my tarot 450 pro fbl?
12 Sep 2016 15:01 #53816 by frago
Hi I was wondering if somebody could help me creating a .ini file for my heli? :dry:
Its a Tarot 450 pro v2 flybarless, has a castle creations ice 50, separated cc-bec 10amp, spektrum ar7200bx, servos hitec in the main rotor and futaba 9257 tail servo and the motor is align 450mx 1700kv.
Im using a 3s battery and the heli was converted to 480 so longer tail boom and main blades.
I used the file in the archive for tarot 450 but the nose of the helicopter goes in the opposite direction (when i press the stick forward the elevator goes down)
I tested the heli with my friends dx7s and works well..
13 Sep 2016 06:35 #53833 by Thomas.Heiss
Replied by Thomas.Heiss on topic can you help me with my tarot 450 pro fbl?
Go go to ELEV mixer channel and try reversing servo normal/inverted settings.
Thomas
21 Sep 2016 03:53 #54082 by frago
Replied by frago on topic can you help me with my tarot 450 pro fbl?
Thanks man! It worked...
I have also downloaded the ini file for a simulator, now heli x finds the controller and I calibrated the joy sticks, there is any way of calibrating or using the switches in the radio on the simulator (trottle hold and fly mode)?
Time to create page: 0.794 seconds
