HOW TO BIND A EACHINE FB90 to a DEVO 10
08 Jan 2017 17:51 #57710 by ltlethel
HOW TO BIND A EACHINE FB90 to a DEVO 10 was created by ltlethel
HOW TO BIND A DEVO 10 running Deviation 5 to a EACHINE FB90 with a DSM2 receiver please help fellas
08 Jan 2017 20:16 - 09 Jan 2017 02:11 #57714 by Cereal_Killer
Replied by Cereal_Killer on topic HOW TO BIND A EACHINE FB90 to a DEVO 10
Reading the manual is usually a pretty good first step... Here's the exact section you need.
EDIT: It won't allow direct linking to specific manual pages, you want sections 9.1
www.deviationtx.com/user-manual/user-manual-7e-10
Model menu
Name your model file
Sellect DSM2 protocol
6 channels
Enter a Fixed-ID [random digits you make up] in that box
Click bind button (while doing necessary steps on receiver end)
Last edit: 09 Jan 2017 02:11 by Cereal_Killer.
08 Jan 2017 23:05 #57716 by ltlethel
Replied by ltlethel on topic HOW TO BIND A EACHINE FB90 to a DEVO 10
the first thing I did was read the manual section on binding. i got it to bind but I won't arm the FB90 book says:
BNF was set to AUX(CH5) to arm and disarm it binds but it wont arm
i dont know which switch that is I toggled all of them on the devo 10 I FORGOT TO MENTION I upgrade my devo 10 with the 4 n 1 moduel
09 Jan 2017 01:22 #57722 by Deal57
Replied by Deal57 on topic HOW TO BIND A EACHINE FB90 to a DEVO 10
I presume you are running Cleanflight? If so, you can set up a switch to Arm. In Deviation for my Devo12e I used the Rud D/R switch on Channel 5 (Aux1), set up with a simple 1-to-1 curve, which will output a high value when 0 (up for me means Armed, similar to Throttle Hold off), and a low value when 1. In Cleanflight under Modes, I set up the Arm mode to Aux1 when the value is over 1500.
You can also set up the sticks to arm by position, but that is a bit trickier.
09 Jan 2017 16:21 #57750 by ltlethel
ok thank you ill try that i'm really not that familiar with cleanfight i'm a newbee I must have moved all these swicthes on the remote trying to figure what (Aux1) was nogo on that
09 Jan 2017 17:07 #57752 by ltlethel
made a video:
09 Jan 2017 17:52 #57755 by Deal57
It appears you have the bind working ok.
The message you're getting at Devo power on about the safe value is because either your throttle isn't in the fully down position or you didn't calibrate your sticks properly.
So the only other thing is to get channel 5 set up in the Mixer menu.
This thread talks about how to do it.
09 Jan 2017 21:20 #57761 by ltlethel
ok it seems I did everything that ibseem in those videos and thank you by the way they really helped. I think my problem is the DEVO 10 switches aren't showing up on cleanflight by the show up on the devo10 is there a switch to activate the switch for it to work in cleanflight
Here's short video
10 Jan 2017 02:20 #57768 by Deal57
The input as seen in the Input monitor tells us that the switches are working, but you have to use the Mixer page to assign a switch to a channel. If that sounds like gibberish to you, you need to read the manual... chapter 9, specifically, section 9.2.4 (for the Devo10) discusses how to assign an input (e.g. the Gear switch) to an output channel using the Mixer.
I can see in the video that you have all four sticks working correctly, so don't change them. But you need to set up the mixer (5-GEAR) to an input switch on channel 5. Once you do that you'll see the switch movement in the Input screen AND you will see the activity as the output goes from -100 to 100 on channel 5 in the Channel Monitor. When that is working, Cleanflight will see the switch on Aux1 and you can set the arm range.
Keep up the good work!
Time to create page: 0.194 seconds
