airplane with nose pitch mix
13 Aug 2017 13:38 #63801 by kaligola
airplane with nose pitch mix was created by kaligola
id like to get my devo 10 mix throttle with elevon
i found this
www.deviationtx.com/forum/model-configs/...-hobbyking-axn#52704
have same modelbut seems not work for me, it stays only like trimmed elevon not change on giving throttle
14 Aug 2017 02:20 - 14 Aug 2017 02:23 #63804 by magic_marty
Replied by magic_marty on topic airplane with nose pitch mix
I think you need to add a mix to the throttle ch that will add down elevator as you throttle up...I have did the same on some of my planes , it takes a bit of trial to get the proper % of mix but it does work..
Last edit: 14 Aug 2017 02:23 by magic_marty. Reason: typo
14 Aug 2017 12:33 #63805 by RoGuE_StreaK
Replied by RoGuE_StreaK on topic airplane with nose pitch mix
Just checking first, did you activate the Gear switch as per the original post's comments? Or if you have a Devo that doesn't have a Gear switch, have you moved this part of the mixer to another switch?
RE: magic_marty's post, you'd actually want to be adding to the elevator channel, using the throttle input as a source. But in your case of elevons you need to do this twice, once per elevon channel.
14 Aug 2017 12:59 #63806 by kaligola
Replied by kaligola on topic airplane with nose pitch mix
Must re check but seemed that Gear switch did not made change. Back home will remove prop and check. Thanks
19 Aug 2017 09:11 #63868 by kaligola
tested without props before maiden, works ok on bench only to make negative value because of reversed channel with mi radio.
great..
19 Aug 2017 21:40 #63871 by RoGuE_StreaK
Just change the throttle input mixer to be the negative curve of what it currently is (make the Scale negative)
23 Aug 2017 06:47 #63915 by kaligola
thats what i did, removed prop, tested its ok.
gonna maiden soon have time to go on field
Time to create page: 0.145 seconds
