Need help for my DLG
- Solmer
16 Aug 2017 16:17 #63822
by Solmer
Need help for my DLG was created by Solmer
Hi! I've built a DLG and I'm trying to programm my Devo for it. I've 3 servos installed in my DLG 1 for the elevator and 2 for the ailerons.. I can control elvator an turns with my setup but I can't programm the Devo to use botha ailerons to incresase / decrease the chamber. i've tried all combinations with no luck....what I need is....
Control both ailerons for turns and...controls the chamber using the channel 3 (throttle).... Any help?
Thanks in advance.
Thanks in advance.
- RoGuE_StreaK
18 Aug 2017 12:01 #63859
by RoGuE_StreaK
Replied by RoGuE_StreaK on topic Need help for my DLG
No rudder?
I've got my DLG setup somewhere, if you give me a few days I could dig it up, sorry got too much happening at the moment (quick pre-bed check)
Which Devo are you using? My model file will need tweaking if it's a 7E
- Solmer
18 Aug 2017 21:20 #63864
by Solmer
Replied by Solmer on topic Need help for my DLG
Hi RoGuE_StreaK !
Thanks for your reply, after checking all the model.ini I realized that was a little mistake
Now is working
Thanks anyway.
Thanks anyway.
Time to create page: 0.045 seconds
Model Configs
Model Requests
- Need help for my DLG
