Dual Rate model file for Flying Wing?
15 Jan 2018 20:08 #66893 by Brett_N
Dual Rate model file for Flying Wing? was created by Brett_N
Anybody have one handy?
15 Jan 2018 23:06 #66897 by Fernandez
Replied by Fernandez on topic Dual Rate model file for Flying Wing?
Maybe this one ? Is a delta model SWIFT, used in U7E.
I normally use a 3 position switch for small - normal - large throw at the flaps.
17 Jan 2018 22:45 #66949 by Gerry
Replied by Gerry on topic Dual Rate model file for Flying Wing?
here is my flying wing ini for 7e
FFS (Forever Fixing Stuff)
19 Feb 2018 03:48 #67576 by Brett_N
Replied by Brett_N on topic Dual Rate model file for Flying Wing?
Both work like a charm - confrimed on Jumper with the simple FT Delta . Thanks gents. Gonna build an FT Spear next and try it on a big airframe.
29 Apr 2018 20:51 #68925 by cluxter
Replied by cluxter on topic Dual Rate model file for Flying Wing?
Gerry wrote: here is my flying wing ini for 7e
Hello; Is this file used as a template or model? Thanks for sharing
29 Apr 2018 23:08 #68928 by Gerry
The ini I posted is a model file I use for a delta wing plane.
29 Apr 2018 23:57 #68930 by cluxter
Gerry wrote: The ini I posted is a model file I use for a delta wing plane.
Thanks a lot
30 Apr 2018 00:09 #68931 by Gerry
have a look at Fernandez ini posted a few above this one as well, his has 3 rates, mine only has 2 rates.
20 May 2018 02:35 #69330 by Gerry
See this thread, it has updated model ini's for delta/flying wing with and without dual rates and a tutorial of how the ini's were made.
www.deviationtx.com/forum/model-template...ith-dual-rate-please
28 Jun 2020 01:39 #76534 by TheLeggacy
Replied by TheLeggacy on topic Dual Rate model file for Flying Wing?
Hi, ive recently got back into RC and have just bought a Jumper T8SG V2. I’ve set up elevons with dual rates from some templates I’ve found. It works ok but all the templates I find have both rates, elevator and ailerons, on one switch. Is there a way to separate the rates? I’ve tried but I just end up with it effecting one servo only. I’m having to program manually as I don’t have access to a working computer right now.
30 Jun 2020 02:31 #76540 by Gerry
find the tutorial in the forum linked above your post, in the virtual channels assign which ever switches you like for each.
Time to create page: 0.284 seconds
