- Model Requests
- Dual Rate model file for Flying Wing?
- Brett_N
15 Jan 2018 20:08 #66893
by Brett_N
Dual Rate model file for Flying Wing? was created by Brett_N
Anybody have one handy?
- Fernandez
15 Jan 2018 23:06 #66897
by Fernandez
Replied by Fernandez on topic Dual Rate model file for Flying Wing?
Maybe this one ? Is a delta model SWIFT, used in U7E.
I normally use a 3 position switch for small - normal - large throw at the flaps.
- Gerry
- Bbrad
17 Jan 2018 22:45 #66949
by Gerry
FFS (Forever Fixing Stuff)
Replied by Gerry on topic Dual Rate model file for Flying Wing?
here is my flying wing ini for 7e
- Brett_N
19 Feb 2018 03:48 #67576
by Brett_N
Replied by Brett_N on topic Dual Rate model file for Flying Wing?
Both work like a charm - confrimed on Jumper with the simple FT Delta . Thanks gents. Gonna build an FT Spear next and try it on a big airframe.
- cluxter
29 Apr 2018 20:51 #68925
by cluxter
Hello; Is this file used as a template or model? Thanks for sharing
Replied by cluxter on topic Dual Rate model file for Flying Wing?
Gerry wrote: here is my flying wing ini for 7e
- Gerry
- Bbrad
29 Apr 2018 23:08 #68928
by Gerry
The ini I posted is a model file I use for a delta wing plane.
- cluxter
29 Apr 2018 23:57 #68930
by cluxter
Thanks a lot
Gerry wrote: The ini I posted is a model file I use for a delta wing plane.
Thanks a lot
- Gerry
- Bbrad
30 Apr 2018 00:09 #68931
by Gerry
have a look at Fernandez ini posted a few above this one as well, his has 3 rates, mine only has 2 rates.
- Gerry
- Bbrad
20 May 2018 02:35 #69330
by Gerry
See this thread, it has updated model ini's for delta/flying wing with and without dual rates and a tutorial of how the ini's were made.
www.deviationtx.com/forum/model-template...ith-dual-rate-please
- TheLeggacy
28 Jun 2020 01:39 #76534
by TheLeggacy
Replied by TheLeggacy on topic Dual Rate model file for Flying Wing?
Hi, ive recently got back into RC and have just bought a Jumper T8SG V2. I’ve set up elevons with dual rates from some templates I’ve found. It works ok but all the templates I find have both rates, elevator and ailerons, on one switch. Is there a way to separate the rates? I’ve tried but I just end up with it effecting one servo only. I’m having to program manually as I don’t have access to a working computer right now.
- Gerry
- Bbrad
30 Jun 2020 02:31 #76540
by Gerry
find the tutorial in the forum linked above your post, in the virtual channels assign which ever switches you like for each.
- Model Requests
Time to create page: 0.200 seconds
Model Configs
Model Requests
