Bayangtoys x16 for the F7
27 Feb 2018 19:00 - 27 Feb 2018 19:11 #67810 by Quell
Bayangtoys x16 for the F7 was created by Quell
Hi friends I found this file for the x16 but it has 12 channels.
What could I do to get this to work on my F7, could I have 1 switch available to assign to return to home or auto land?
I'm just getting aquanted to deviation. It binds fine and arms the motors fine, but it's hard to tell if dual rates or any other switches do anything because of the props being OFF!
Here's what I found, will it work as is on the F7? If you could please tell me what each switch would do.
Right now I'm using the Bayangtoys protocol, with the X16 AH model file. Maybe this is fine to use, does anyone know what each switch does with the X16 AH file I'm using right now?
name=Rolling Thunder(x16)
mixermode=Advanced
[radio]
protocol=Bayang
num_channels=11
fixed_id=123456
tx_power=150mW
[channel1]
template=complex
[mixer]
src=AIL
dest=Ch1
scalar=60
curvetype=expo
points=25,25
[mixer]
src=AIL
dest=Ch1
switch=FMODE1
scalar=80
usetrim=0
curvetype=expo
points=25,25
[mixer]
src=AIL
dest=Ch1
switch=FMODE2
usetrim=0
curvetype=expo
points=25,25
[channel2]
template=complex
[mixer]
src=ELE
dest=Ch2
scalar=60
usetrim=0
curvetype=expo
points=25,25
[mixer]
src=ELE
dest=Ch2
switch=FMODE1
scalar=80
usetrim=0
curvetype=expo
points=25,25
[mixer]
src=ELE
dest=Ch2
switch=FMODE2
usetrim=0
curvetype=expo
points=25,25
[channel3]
safetysw=RUD DR1
safetyval=-110
template=simple
[mixer]
src=THR
dest=Ch3
curvetype=expo
points=0,0
[channel4]
template=complex
[mixer]
src=RUD
dest=Ch4
scalar=60
curvetype=expo
points=25,25
[mixer]
src=RUD
dest=Ch4
switch=FMODE1
scalar=80
usetrim=0
curvetype=expo
points=25,25
[mixer]
src=RUD
dest=Ch4
switch=FMODE2
usetrim=0
curvetype=expo
points=25,25
[channel6]
template=simple
[mixer]
src=ELE DR1
dest=Ch6
curvetype=expo
points=0,0
[channel9]
template=simple
[mixer]
src=AIL DR1
dest=Ch9
curvetype=zero/max
points=0
[trim1]
src=LEFT_V
pos=TRIMLV+
neg=TRIMLV-
value=-10,0,0
[trim2]
src=RIGHT_V
pos=TRIMRV+
neg=TRIMRV-
[trim3]
src=LEFT_H
pos=TRIMLH+
neg=TRIMLH-
[trim4]
src=RIGHT_H
pos=TRIMRH+
neg=TRIMRH-
value=100,0,0
[timer2]
type=countdown
time=10
[datalog]
switch=None
rate=1 sec
[safety]
Auto=min
[gui-128x64]
V-trim=59,10,1
H-trim=5,59,3
V-trim=65,10,2
H-trim=74,59,4
Small-box=2,22,Ch3
Small-box=2,31,Timer1
Small-box=2,40,Timer2
Model=75,20
Battery=102,1
Toggle=4,10,0,9,0,RUD DR
Toggle=13,10,0,5,0,None
Toggle=22,10,0,4,0,None
Toggle=31,10,0,0,0,None
Toggle=40,10,0,0,0,None
TxPower=102,7
quickpage1=Telemetry monitor
Last edit: 27 Feb 2018 19:11 by Quell. Reason: Info
Time to create page: 0.135 seconds
