GS-XXD158 Small Drone
01 May 2019 16:47 #74181 by Fer
GS-XXD158 Small Drone was created by Fer
I got this little drone many months ago. It is a nice flyer, beautiful too, and the tx it comes with is not as terrible as many others.
But still compared to Devo... well, does anyone know what protocol it comes with?
01 May 2019 19:51 #74184 by Moeder
Replied by Moeder on topic GS-XXD158 Small Drone
The same as usual: make some pictures from tx or drone pcb so we now what rf chip is used. Then we work on from there.
02 May 2019 17:48 - 02 May 2019 18:50 #74192 by Fer
Replied by Fer on topic GS-XXD158 Small Drone
Here are two pics from the inside of the tx. I think this is not one of our favorite rf chips...
I hope this is enough to determine if it can be deviated or not, as the drones board can not be easily viewed. This thing has so many tiny screws holding the frame :)
Last edit: 02 May 2019 18:50 by Fer.
02 May 2019 18:52 - 02 May 2019 19:40 #74194 by Moeder
Can you try XN297DUMP on it? I attached a devo10 build for you to load. Once flashed select a free model and select protocol XN297DUMP. After turning on the toy transmitter, go to Transmitter Menu -> XN297 Dump, press right once to select "Scan" and press ENT. See if the scan stops on a channel and the bottom status changes to "Valid CRC found". If no success, you can try changing data rate to 250 kbps in the protocol options and run the scan again.
Last edit: 02 May 2019 19:40 by Moeder.
02 May 2019 21:24 #74197 by Fer
I installed it. I am getting no valid CRC for either 250k, 1Mb, or 2Mb. I sporadically get some values for 2Mb, but not a valid CRC at all. I have left it scan through all channel for all options, and didn't get anything.
02 May 2019 21:46 #74198 by Moeder
Most likely not a xn297 device then. And markings on the ic you can make out?
02 May 2019 21:53 #74199 by Fer
Moeder wrote: Most likely not a xn297 device then. And markings on the ic you can make out?
ic? you mean the quad's board? If so, i will try to open it tomorrow after work.
02 May 2019 21:57 #74200 by Moeder
The black chip you can see in the tx pcb pictures
02 May 2019 22:13 #74201 by Moeder
One more thing: you could also try xn297dump with protocol option scrambled set to off. I doubt it will work though
03 May 2019 04:24 #74204 by Fer
Moeder wrote: One more thing: you could also try xn297dump with protocol option scrambled set to off. I doubt it will work though
Ok i will try this after i am back home. As for the ic, it says nothing on it.
03 May 2019 12:57 #74208 by Fer
It didn't work with scramble off either. I am only getting a couple of random readings on 2Mbits, but no valic CRC,
Time to create page: 0.103 seconds
