Config UMX Ultrix BNF Basic (EFLU6450)
30 May 2020 06:03 #76379 by ericart63
Config UMX Ultrix BNF Basic (EFLU6450) was created by ericart63
Could someone help me with the configuration of a UMX Ultrix BNF Basic aircraft (EFLU6450) with my Devo 8s radio with Deviation software
thank you in advance
Eric
Bonjour,
Quelqu'un pourrait il m'aider pour la configuration d'un avion UMX Ultrix BNF Basic (EFLU6450) avec ma radio Devo 8s avec le software Deviation
Merci d'avance
Eric
30 May 2020 08:46 - 30 May 2020 09:46 #76380 by -=Hubi-Dirk=-
Replied by -=Hubi-Dirk=- on topic Config UMX Ultrix BNF Basic (EFLU6450)
Motormixing seems to made by the Rudder input. If not take a look the attached config as an example for controlling throttle and direction with two motors:
- Ch 2 = left Motor, Ch 3 = right Motor, they speed up in synchron mode (TX = Mode 2).
- Rudder right = Ch 1 => speed up left Motor
- Rudder left = Ch 4 => speed up right Motor
For the Elevator and Aileron you have to setup also complex mixer.
Greetings
Dirk
Last edit: 30 May 2020 09:46 by -=Hubi-Dirk=-.
30 May 2020 11:33 #76381 by ericart63
Replied by ericart63 on topic Config UMX Ultrix BNF Basic (EFLU6450)
Thank you
Time to create page: 0.076 seconds
