Documenting the ini file
17 Apr 2013 09:35 #9001 by RandMental
Documenting the ini file was created by RandMental
rbe2012 wrote: Oops, this was not intended... documentation is often boring :whistle:
But to be honest: I thought about that too. This thread showed again that many (only some?) people edit their config files instead of using a potentially complex user interface to change the values. A documentation should point to the corresponding place in the gui.
Should we open a new thread beyond "How To"?
For me the big advantage of understanding and being able to read the Modelxx.ini files is that one can quickly read through a file provided by someone and understand how the TX is configured and how it will behave - all in one place on one screen.
The alternative would be to connect your tx to the PC, load the ini file and go through each screen trying to remember each detail - not a good use of my time.
  • rbe2012
  • rbe2012's Avatar
17 Apr 2013 09:51 #9002 by rbe2012
Replied by rbe2012 on topic Documenting the ini file
The use of the ini-file is indisputable - I use them the same way, but all my configs were created from the gui; just to be sure of their correctness.
Now let's make a real job of it. Where should we start?
I see these steps (all comments in brackets are my opinion):
  • search a place to save intermediate and final results (the forum is not because it makes teamwork difficult; I would prefer a new bitbucket repo or something similar)
  • define format (should be similar to the regular manual)
  • define a structure (easiest: the main blocks "global", radio, mixer, gui-qvga...)
  • for every structure element: describe the use of this block, describe the possible parameters, their possible values, the page / place in the gui where it will be set in the real tx / emulator (separate for standard and advanced) and give some (one) example
  • write a general description where everything what was announced to be a problem for some users is mentioned: filesystem, editor, line endings, 4k-size, comments in the file, the way the config is read, stored and written, ...
  • search for volunteers who will write one section
  • rbe2012
  • rbe2012's Avatar
17 Apr 2013 10:21 - 17 Apr 2013 10:22 #9003 by rbe2012
I have taken the manual file from PBs manual repo, cleared all but saved the formatting. I put a few headlines inside to give you a clue what I think.
I am anxious to see if uploading a fodt-file will work directly...
EDIT: no, did not... zipped now, should run.
File Attachment:
File Name: DeviationM...nfig.zip
File Size:27 KB
Last edit: 17 Apr 2013 10:22 by rbe2012.
17 Apr 2013 15:31 - 17 Apr 2013 15:33 #9005 by RandMental
Replied by RandMental on topic Documenting the ini file
100% happy with the approach, will look at the .fodt files tonight and add what I can contribute. A new repo on bitbUcket would be a great way to manage it, we can move it to PB's document repo once done. If you open it I'll push my changes back.
(I can understand why FDR has blocked certain files types - This .fodt file zips down to <20% of normal size)
Last edit: 17 Apr 2013 15:33 by RandMental.
  • rbe2012
  • rbe2012's Avatar
17 Apr 2013 18:27 #9007 by rbe2012
Ok, I will open a new repo - will see how to set the rights correctly so you can push too (if I don't get it we will work with clones and pull requests as usual).
PB has chosen the fodt format because it is version control system compatible. It is human readable, because it is a large xml-file. So we can expect that zipping will find many equal strings to compress really good.
17 Apr 2013 18:40 #9008 by FDR
Replied by FDR on topic Documenting the ini file
RandMental wrote: (I can understand why FDR has blocked certain files types - This .fodt file zips down to <20% of normal size)
Actually I hasn't blocked the .fodt intentionally, it simply was not on the list of allowed extensions by default... ;)
17 Apr 2013 18:53 - 17 Apr 2013 18:56 #9009 by RandMental
FDR wrote: Actually I hasn't blocked the .fodt intentionally, it simply was not on the list of allowed extensions by default... ;)
Well is seems with good reason :)
The only problem I noticed is that the system does not warn a user when it is not loading a file, does Kunena not have an option to alert the user?
Last edit: 17 Apr 2013 18:56 by RandMental.
17 Apr 2013 19:14 #9010 by FDR
It usually alerts, but at the top of the page, which is not always visible unless you go top...
  • rbe2012
  • rbe2012's Avatar
17 Apr 2013 20:53 #9011 by rbe2012
RandMental,
I cloned PB's manual repository here: deviation-modelconfig-manual . I gave you write access, but I can not test if it will work.
The file uploaded some posts ago is committed.
18 Apr 2013 20:24 #9039 by RandMental
I added a file with my additions and a few format suggestions, however I might have messed up your original in the push process. (My mercurial skills is not what it should be)
  • rbe2012
  • rbe2012's Avatar
18 Apr 2013 20:36 - 18 Apr 2013 20:37 #9040 by rbe2012
It has worked somehow - I have seen two commits, but I will look into the files tomorrow.
Last edit: 18 Apr 2013 20:37 by rbe2012.
  • rbe2012
  • rbe2012's Avatar
19 Apr 2013 06:28 #9050 by rbe2012
I have looked at your doc.
We have two different ways to work on the documentation together: we can do it with means of mercurial (that means we work with the same doc and commit the changes and pull / push often) or we can do it without the help of mercurial (we work on different docs and put them together later).
I prefer the last one because we are more independent from each others work. We will only have to make sure that at the end we have a single document. What I mean: the resulting document should look like it is written from a single author, homogeneous and completely rounded.
If you agree we should inform each other which part we will work on next.
At first I will transfer the whole model.c method in the structure. Everything what the method knows will be described so this will give us the complete overview.
I go on working on the doc I created before.
19 Apr 2013 11:24 - 19 Apr 2013 18:52 #9053 by RandMental
Happy with you proposal that we do add what we can in separate documents for now.
Truth is at this point I don't have to much factual info on the ini file to add. For small additions or suggestions to your doc I shall do a pull request and you decide - we can't have two editors on one doc at the same time :).
Last edit: 19 Apr 2013 18:52 by RandMental.
19 Apr 2013 17:18 #9061 by PhracturedBlue
Replied by PhracturedBlue on topic Documenting the ini file
Thanks guys for tackling this. I think it will be a very valuable addition to the documentation.
20 Apr 2013 08:59 #9072 by RandMental
Hi RBE, pushed a few updates to the manual and tried to remove my original draft document, however it is still in the repository. Could you please delete it, we use you file as the working copy.
  • rbe2012
  • rbe2012's Avatar
20 Apr 2013 10:41 #9073 by rbe2012
Hmmm, a new challenge... I never have deleted a file from a repo...
I think I have to pull, mark the file as to be forgotten and push again... I will try later.
20 Apr 2013 20:00 #9081 by RandMental
That is what I tried, but perhaps my write access rights dont allow it. Did not get any errors from mercurial though.
21 Apr 2013 00:52 #9084 by PhracturedBlue
do an 'hg rm filename' to remove it. then do an 'hg commit' to commit the change.
  • rbe2012
  • rbe2012's Avatar
21 Apr 2013 07:28 #9088 by rbe2012
RandMental wrote: That is what I tried, but perhaps my write access rights dont allow it. Did not get any errors from mercurial though.
It has nothing to do with write access - the mercurial server is not the place where we do changes to the repo. I can't do that either.
This has to be done in our local copy. The command PB said will do the trick (I did not know this, but it is similar to git).
  • rbe2012
  • rbe2012's Avatar
21 Apr 2013 08:34 #9091 by rbe2012
Someone was faster than me :P ...again.
Time to create page: 0.110 seconds
