need help for simulator - t8sg v2 plus
28 Dec 2018 12:46 - 28 Dec 2018 13:20 #72132 by Biasi
Hi everyone
I received the jumper t8sg plus a few days ago, I calibrated and connected to the PC to use it with the simulator.
I tried both freeriders and liftoffs but the movements of the sticks respond only from 0 to 100 and not for the whole movement from -100 to 100.
In the radio mixer everything seems to be regular ...
can you help me?
is there an already preconfigured simulator profile?
thanx in advance
Last edit: 28 Dec 2018 13:20 by Biasi.
28 Dec 2018 15:31 #72133 by 52dgj
Replied by 52dgj on topic need help for simulator - t8sg v2 plus
This is my model file,You can adjust the value of each point in the mixer to achieve the output you need. This is my method:)
28 Dec 2018 17:21 #72134 by Biasi
Replied by Biasi on topic need help for simulator - t8sg v2 plus
tnx very much, i'll try asap!
:-P
29 Dec 2018 07:12 #72138 by Biasi
I tried your settings but it still did not work except for the ELEV movement that followed the complete path.
I copied the stick mixer settings for the other 3 movements and now it works perfectly!
18 Feb 2019 18:58 #72919 by windelwilli
Replied by windelwilli on topic need help for simulator - t8sg v2 plus
could you please up,load a model file ....
25 Feb 2019 12:37 #73008 by windelwilli
Biasi wrote: I tried your settings but it still did not work except for the ELEV movement that followed the complete path.
Please give us your Model ini file
25 Feb 2019 15:14 #73009 by Biasi
hi,
u can find it as attachment!
wish it can hel u
04 Mar 2019 11:54 #73187 by windelwilli
I´m so sad, because this file doesn´t work also...
I go complete crazy
14 Mar 2019 09:06 #73347 by windelwilli
Could you eventually make a video ?
I can't understand why this don't work on my setup ???
I wanna fly this freerider sim !!! Ohhhh my GOD
05 Apr 2019 11:59 #73703 by windelwilli
i wanna play freerider now on my PC ;-(
please help me someone....
05 Apr 2019 23:27 #73709 by hexfet
Replied by hexfet on topic need help for simulator - t8sg v2 plus
A problem with usbhid on windows was recently fixed, so upgrade to the latest nightly build unless you know the usbhid is working.
The attached model file works at least with the demo version of fpv freerider.
10 Apr 2020 19:25 #76177 by roso
Replied by roso on topic need help for simulator - t8sg v2 plus
tambem estou igual...nao estas sozinho.
Time to create page: 0.085 seconds
