DSM Telemetry support
05 Mar 2015 14:58 - 05 Mar 2015 15:12 #29354 by linux-user
Replied by linux-user on topic DSM Telemetry support
Sorry,
devo10-v4.0.1-8d9113c isn't the solution.
Telemetry monitor shows strange values:
either:
Temp1=Temp2=Temp3=Temp4=29C
Volt1=Volt2=Volt3=4.8V (1s Lipo)
RPM1=RPM2=5760
or even:
some other values:
should I write down them?
... and some more bugs:
- Channel-Monitor is messed up
(Ch1 Ch2 are missing, but it shows Virt1, Virt2 Virt3)
- there is am menu for "3. USB" - but not working
Last edit: 05 Mar 2015 15:12 by linux-user. Reason: more Bugs
05 Mar 2015 15:48 - 05 Mar 2015 16:03 #29355 by Indigo
Replied by Indigo on topic DSM Telemetry support
Oops sorry. Ok, it's now fixed. Also zero values for Volts and RPM are shown in error colour.
I just tried USB mode and it is working. You might need the file system for latest nightly, so I have uploaded the 3 file system (fs) zips as separate downloads.
RE: Channel Monitor
Would it make sense if title "Channel output" was changed to "Mixer output".
Last edit: 05 Mar 2015 16:03 by Indigo.
05 Mar 2015 16:16 #29356 by mwm
Replied by mwm on topic DSM Telemetry support
Indigo wrote: Would it make sense if title "Channel output" was changed to "Mixer output".
I still think that would make sense :-).
05 Mar 2015 16:29 - 05 Mar 2015 16:36 #29357 by linux-user
Indigo wrote: Oops sorry. Ok, it's now fixed. Also zero values for Volts and RPM are shown in error colour.
Yes, that is true, but none of the values displayed are valid.
Indigo wrote: RE: Channel Monitor
I don't think it is necessary to change the name. "Virtual channels" are also sort of channels.
Channel Monitor:
does not work with small fonts. (/media/config.ini)
USB:
is working, sorry might have been my fault.
Telemetry monitor:
no valid values as described above. (MiniCP only supports Temp1 and Volt2)
Last edit: 05 Mar 2015 16:36 by linux-user.
05 Mar 2015 17:02 #29358 by Indigo
Ok, that could only be one thing. New version will be uploaded within 5 mins.
05 Mar 2015 17:44 - 05 Mar 2015 17:47 #29364 by linux-user
Sorry,
Telemetry Monitor:
now all "0" in "error color" (=inverted), no matter if RX is bound or not.
Channel Monitor:
still does not like small fonts
Last edit: 05 Mar 2015 17:47 by linux-user.
06 Mar 2015 08:03 #29390 by Indigo
Ok, new version addressing those 2 issues :woohoo:
Telemetry Monitor - unable to test myself but should be fixed
Channel Monitor - fixed *
* Old bug, previously 2nd page "Stick Inputs" with small fonts would crash, but since my update to scrollable both pages would crash. It took some time to find the cause and just as long to fix.
Datalog not working - I'll look into it.
06 Mar 2015 09:03 - 06 Mar 2015 09:43 #29393 by linux-user
Indigo wrote: Telemetry Monitor - unable to test myself but should be fixed
Hi, Indigo
deviation-devo10-v4.0.1-de99565
Channel Monitor - fixed - confirmed
Telemetry Monitor:
still showing all 0, no matter if model bound or not. (inverted)
To clarify: This is not only the "Telemetry monitor" but TX doesn't display any telemetry-values in text-box as well.
Edit:
I left the previous version (deviation-devo10-v4.0.1-8d9113c.dfu) powered on over night, and got locked out. (RX not binding automatically)
- switched telemetry off => RX is binding.
- switched telemetry on => RX binds again.
This was done without power-cycling anything.
Last edit: 06 Mar 2015 09:43 by linux-user. Reason: clarification
06 Mar 2015 11:52 #29394 by Indigo
Ok, Telemetry Monitor wasn't updating the display, it should now work.
Thanks for testing this. :)
06 Mar 2015 12:14 #29395 by linux-user
telemetry still only shows "0"
deviation-devo10-v4.0.1-c05d8ac (I only updated the dfu)
06 Mar 2015 12:46 #29396 by Indigo
Ok, it should work now.
06 Mar 2015 13:07 #29398 by linux-user
:sick: deviation-devo10-v4.0.1-4dc1002 still displays only 0
06 Mar 2015 13:35 - 06 Mar 2015 13:48 #29399 by Indigo
Sorry. :huh:
If this doesn't work, I'll have it update all display values to make sure it's actually reading data ok.
Edit: I've added 2 more just for you. :(
* display non-zero
* display all values
Last edit: 06 Mar 2015 13:48 by Indigo.
06 Mar 2015 14:04 #29401 by linux-user
Sorry still all "0"s
What I am not understandig: this has been working before your merge with the nightly. Is there something fundamental different now?
At this point I am thinking, if I am doing something wrong.
06 Mar 2015 14:17 - 06 Mar 2015 14:41 #29402 by linux-user
Indigo wrote: Edit: I've added 2 more just for you. :(
* display non-zero
neither is working for me.
I am thinking of going back to the last one that was working to crosscheck if I am doing something wrong.
Edit:
to crosscheck I flashed the nightly "deviation-devo10-v4.0.1-a4e6135.dfu"
Only the dfu; file system unchanged.
- telemetry is working as expected
Last edit: 06 Mar 2015 14:41 by linux-user.
06 Mar 2015 14:55 #29403 by Indigo
It could be the merge with the nightly, but unlikely.
I've uploaded some more.
Try -disp_all_values_v2 first because if that doesn't work the other 2 won't work either.
06 Mar 2015 15:03 - 06 Mar 2015 15:22 #29404 by linux-user
disp_all_values_v2 isn't working either.
When trouble-shooting it is always the same question:
What was the last change before the error occured?
If I remember correct:
after the merge it did display some values, but totally invalid ones.
Then while trying to eliminate the invalid values we ended up that no values at all are displayed. #29357 and #29354
Last edit: 06 Mar 2015 15:22 by linux-user.
06 Mar 2015 15:43 #29406 by Indigo
I've gone back to before merge.
Try all_values_v3 first. If working try non_zero_v3 next.
06 Mar 2015 16:09 #29408 by linux-user
all_values_v3 didn't work
06 Mar 2015 18:15 #29410 by Indigo
In that case it could only be one thing, :ohmy:
Try this one :unsure:
Time to create page: 0.208 seconds
