DSM Telemetry support
06 Mar 2015 18:29 - 06 Mar 2015 20:02 #29411 by linux-user
Replied by linux-user on topic DSM Telemetry support
deviation-devo10-disp_non_zero_v4 and deviation-devo10-disp_all_values_v4
are working. :)
Edit:
Your last version of deviation-devo10-v4.0.1-4dc1002 does work as expected.
Could not find any bugs jet :woohoo:
Now I let it run over night and see what it does tomorrow.
Thank you very much
Manfred
Last edit: 06 Mar 2015 20:02 by linux-user. Reason: more Details
07 Mar 2015 06:44 - 07 Mar 2015 06:51 #29420 by linux-user
now it comes to the sad and probably difficult part. I try to describe my observations as precise as possible.
Test-environement:
Devo10 and MiniCP which supports TEMP1 amd Volt2
TX powered via 12V AC adapter.
I don't have a power-source for the RX that lasts longer than 4h.
1.) let TX powered on over night ~11h (with telemetry on)
2.) powered on RX
=> no connection to RX, which I think should work.
3.) switched telemetry off
=> connection to RX is working
4.) switched telemetry ON
- no telemetry values for ~1min (all 0 inverted)
- after ~1min valid telemetry values showed up (as it should)
- but eventually got inverted again (should not, as RX is 3m away)
- Values came back after ~30s -1min
5.) Switched USB mode on
=> is working,
6.) Switched USB mode off
=> telemetry is working as expected!
- valid telemetry values are displayed.
- they don't get inverted anymore.
- everything is working as it should.
All in all everything seems to work as expected, but I am afraid, that
eventually could happen a LOSS OF CONNECTION.
datalog isn't working for me.
Last edit: 07 Mar 2015 06:51 by linux-user.
07 Mar 2015 08:17 #29422 by Indigo
Replied by Indigo on topic DSM Telemetry support
Thank you for testing.
Ok, telemetry works but does not update constantly as it should. vlad_vy reported similar problem with Devo telemetry after a particular change was made. Since that change vlad_vy has been using a custom build with the change reversed. I'd like you to test that and see if it works better.
If it is worse, please try v2 of the last one.
07 Mar 2015 15:42 #29433 by linux-user
I couldn't find any telemetry related bugs in deviation-devo10-vlad_vy.zip until now. Need to test longer.
One new bug in mixer page:
(tested with small fonts)
- grap the attached model2.ini
- goto mixer page
- goto to i.e. "ch7 DR&Expo"
- scroll down
=> page becomes empty half way down.
this bug wasn't there in nightly 2015-03-05
"deviation-devo10-v4.0.1-a4e6135"
But it is there in nightly 2015-03-07
"deviation-devo10-v4.0.1-35e768d"
Could you provide more info, what I should look for?
what should be the difference between
"devo10-vlad_vy" and "devo10-v4.0.1-4dc1002_v2"?
greetings
Manfred
07 Mar 2015 16:12 #29434 by Indigo
v2 is a code tidy up of "devo10-v4.0.1-4dc1002". There should be no change.
"devo10-vlad_vy" is v2 plus reversing the change that vlad_vy said made telemetry worse.
Both are latest nightly merged with telemetry. Sounds like you have found a bug in nightly.
I was hoping Devo telemetry with "devo10-vlad_vy" would be better than v2. If it's the same and it also works for vlad_vy then that is the better version.
Did you have telemetry 'slow to update' problem with either or both?
07 Mar 2015 16:23 - 07 Mar 2015 16:35 #29435 by linux-user
Indigo wrote: I was hoping Devo telemetry with "devo10-vlad_vy" would be better than v2. If it's the same and it also works for vlad_vy then that is the better version.
I only tested devo10-vlad_vy so far and no telemetry issues jet.
Should I test "v2" as well? (I didn't even download V2 jet)
Indigo wrote: Sounds like you have found a bug in nightly.
Should I file a ticket in Bug-Tracker?
Last edit: 07 Mar 2015 16:35 by linux-user.
07 Mar 2015 17:19 #29436 by Indigo
No need to test v2.
The bug is caused by my fix for #606. I have found the cause and it will be fixed in next nightly.
I have just uploaded: deviation-devo10-v4.0.1-a0f31b6
It is "devo10-vlad_vy" plus new fix for #606. And a change that might fix telemetry 'slow to update' problem.
07 Mar 2015 17:32 #29437 by linux-user
Indigo wrote: I have just uploaded: deviation-devo10-v4.0.1-a0f31b6
I could confirm 'slow to update' with nightly 2015-03-05 "deviation-devo10-v4.0.1-a4e6135" witch isn't there in "devo10-vlad_vy"
07 Mar 2015 17:57 - 07 Mar 2015 18:06 #29438 by linux-user
No telemetry values displayed
All telemetry inverted
Mixer page seems to work.
In regard to telemetry IMHO "devo10-vlad_vy" was the best right now.
Last edit: 07 Mar 2015 18:06 by linux-user.
07 Mar 2015 18:14 - 07 Mar 2015 18:31 #29439 by Indigo
linux-user wrote: I could confirm 'slow to update' with nightly 2015-03-05 "deviation-devo10-v4.0.1-a4e6135" witch isn't there in "devo10-vlad_vy"
That's great. So Devo telemetry is now working properly without issues? :woohoo:
linux-user wrote: I left the previous version (deviation-devo10-v4.0.1-8d9113c.dfu) powered on over night, and got locked out. (RX not binding automatically)
- switched telemetry off => RX is binding.
- switched telemetry on => RX binds again.
This was done without power-cycling anything.
I want to determine if this is a telemetry bug or protocol bug.
Does it happen if telemetry is switched off and left switched off?
Last edit: 07 Mar 2015 18:31 by Indigo. Reason: more detail
07 Mar 2015 18:43 - 07 Mar 2015 19:02 #29441 by linux-user
Indigo wrote: Re: The loosing binding problem.
I want to determine if it is a telemetry bug or protocol bug.
Does it happen if Telemetry is switched off and left switched off?
This tends to become difficult to tell, as I am not sure to be able to reproduce this.
But:
1.) cmpang reported Devo protocol being reliable with telemetry switched off #28056 ff
2.) This seems to correlate with my experience a year ago #525
Edit:
I may try to test this but don't expect any result before end of next week. Every test run lasts one night, and I won't trust one single run.
Last edit: 07 Mar 2015 19:02 by linux-user.
08 Mar 2015 00:23 #29449 by Indigo
cmpang recently reported it as fixed ON DSM2/X protocol #29304
So I've made the same change to Devo protocol v2 below.
Available for download here :
"v4.0.1-c0b203a" is same as "devo10-vlad_vy" merged with next nightly.
"v4.0.1-c0b203a_v2" is same as above with fix for #525
I'd like to publish v2 as a test version in the downloads section, but first I need confirmation that Devo telemetry is still working. Anyone? :whistle:
08 Mar 2015 07:41 - 08 Mar 2015 07:42 #29451 by linux-user
Indigo wrote: "v4.0.1-c0b203a" is same as "devo10-vlad_vy" merged with next nightly.
Hi Indigo,
quick test of deviation-devo10-v4.0.1-c0b203a_v2.zip looks promising :)
I will fly it today, and then see what next "over night test" tells us.
- over night test with "devo10-vlad_vy" ended with lost control.
Are you saying, that "devo10-vlad_vy" doesn't include the fix you have done for DSM2/X?
And v4.0.1-c0b203a_v2 should include it?
Last edit: 08 Mar 2015 07:42 by linux-user.
08 Mar 2015 08:14 #29452 by Indigo
Yes, only v4.0.1-c0b203a_v2 has the fix and I'm confident that it will fix the problem.
08 Mar 2015 12:29 #29454 by vlad_vy
Replied by vlad_vy on topic DSM Telemetry support
It's not related to telemetry, but 'Trims' and 'Datalog' pages have a bug with page scrolling.
I can't scroll page by mouse in emulator, but can scroll page by switching objects selection by buttons. Devo 8 and Devo 12 emulator. #607
09 Mar 2015 06:26 #29478 by Indigo
The above issue has been fixed.
A new version is now available:
bitbucket.org/Indigo1/deviation/downloads
09 Mar 2015 06:57 - 13 Mar 2015 09:31 #29479 by linux-user
Indigo wrote: So I've made the same change to Devo protocol v2 below.
now comes the sad and probably difficult part :sick:
1.) I, left devo10-v4.0.1-c0b203a_v2 (Devo protocol fixed-ID with telemetry ON) powered on for some hours. (RX powered off)
=> no connection to RX anymore (when powering on RX)
2.) same test with telemetry switched OFF:
=> RX still connects instantly.
Could anyone confirm this?
cmpang?! :whistle:
Something within the telemetry code must have the possibility to disrupt transmission. #565 #525 #21247
BTW:
This topic is named "DSM Telemetry support"
Shouldn't we have a separate thread for Devo protocol?
Edit:
follow up -support-for-walkera-telemetry
Last edit: 13 Mar 2015 09:31 by linux-user.
09 Mar 2015 10:26 - 09 Mar 2015 14:04 #29485 by Thomas.Heiss
Replied by Thomas.Heiss on topic DSM Telemetry support
Indigo wrote: @Thomas.Heiss - If you have the time (this weekend maybe?), can you please test the latest - see other thread. Thank you. :)
Spektrum DSMx testing deviation-devo10-v4.0.1-c0b203a_v2.zip (Indigo nightly):
Found bugs:
- temp displayed as "18186C" when no temperature sensor is added to TM1000 (AR6210, AR600, AR8000)
- Bat: displays 4.94V / 5.05V
- RxV: displays 12.2V
-> Bat + RxV is switched on TM1000 and connected RX (possibily used to be working on 92e1705 as I can remember)
- fades/frames: will have to further detail test with multiple Spektrum RX:
-> previous collected and shown "fades" (e.g A/L) where erased to 0 after connection was re-established
-> DX8 always showed the last collected fades from RX, even telemetry link has been gone, never dropped fades (e.g AR6210 fades 255)
-> NOT_CONNECTED black inverted fields (B/R) on Devo10 on AR8000 get activated and display numbers once HF-link is weak / lost (framelosses/holds) (as described in previous posts in this thread)
-> A/L on AR8000 still show various fast changing / blending high 5-digit numbers (>9999) once HF-link is bad (framelosses) (as described in previous posts in this thread)
Greetings
Thomas
Last edit: 09 Mar 2015 14:04 by Thomas.Heiss. Reason: DSMx testing
09 Mar 2015 11:06 #29486 by vlad_vy
Walkera telemetry has own thread, but at 'Feedback & Questions'
www.deviationtx.com/forum/3-feedback-que...or-walkera-telemetry
Will be better to move this tread to 'Protocol Development'.
09 Mar 2015 11:43 #29488 by FDR
Replied by FDR on topic DSM Telemetry support
I've moved it...
Time to create page: 0.376 seconds
