skyartec compatibility
27 Mar 2013 00:49 - 28 Mar 2013 03:10 #8128 by dc59
Replied by dc59 on topic skyartec compatibility
Hexperience wrote: I take it this applies to both the skyartec module and a cc2500-pa bought off of ebay?
As long as we find the correct pins on the module we'll be ok right? This is what mine says...
So long as I match up mosi to si (etc) ??
Cheers
Hi Hexperience,
Your picture is a XL2500-D03 module,it's same as mine!
I think deviation should work fine with CC2500-PA module as well,if you got correctly pin connection.
Last edit: 28 Mar 2013 03:10 by dc59.
27 Mar 2013 04:19 - 27 Mar 2013 04:22 #8130 by Hexperience
Replied by Hexperience on topic skyartec compatibility
Thanks, good to know it will work, but I'm wondering about this:
Does that mean I have to put 3.3v to ALL 3 of those places?
Would anyone have a diagram of how to wire in these modules? The photo in the manual is a bit hard to see where the wires are really going.
Last edit: 27 Mar 2013 04:22 by Hexperience.
27 Mar 2013 04:58 #8131 by dc59
"Does that mean I have to put 3.3v to ALL 3 of those places?"
yes,you are right!
if you use XL2500-D03 module,you should put 3.3v to VCC & PAEN.
27 Mar 2013 06:15 - 27 Mar 2013 06:18 #8132 by vlad_vy
Replied by vlad_vy on topic skyartec compatibility
I'm not sure. Datasheet for very similar module:
wenku.baidu.com/view/2a2f4e737fd5360cba1adb94.html
wenku.baidu.com/view/1dafd519a76e58fafab0035b.html
PA_EN: When Tx status set '1', Rx set '0'
LNA_EN: When Rx status set '1', Tx set '0'
Possible PA_EN and LNA_EN have to be mutually inverted.
Last edit: 27 Mar 2013 06:18 by vlad_vy.
27 Mar 2013 09:26 - 27 Mar 2013 09:26 #8136 by stein@office-center.no
Replied by stein@office-center.no on topic skyartec compatibility
PhracturedBlue wrote: I have updated the module installation instructions for both the CC2500 and A7105 modules. You can find the updated instructions here:
www.deviationtx.com/repository/Documenta...duleInstallation.pdf
The next release is imminent. Mostly it is waiting for:
b) me to update the documentation
After the recent discussions - does this require the Modulinstallation.pdf file to be updated? (I need to give the module and radio to my friend for soldering and want to be sure he has the information required.)
Thanks.
Stein Holstad
Norway
Last edit: 27 Mar 2013 09:26 by stein@office-center.no. Reason: misspelled
27 Mar 2013 09:52 - 27 Mar 2013 09:58 #8138 by vlad_vy
MOSI: master output, slave input (output from master); MOSI = (si)(digital input)
MISO: master input, slave output (output from slave); MISO = (so)(digital output)
Last edit: 27 Mar 2013 09:58 by vlad_vy.
27 Mar 2013 11:01 #8139 by Hexperience
Sorry, I don't know what that diagram really means...
Can you guys help me fill in this..
(sorry I know I'm thick)
27 Mar 2013 14:15 - 27 Mar 2013 14:17 #8144 by vlad_vy
I think it will be:
Last edit: 27 Mar 2013 14:17 by vlad_vy.
28 Mar 2013 00:49 - 28 Mar 2013 03:08 #8164 by dc59
Delete
Last edit: 28 Mar 2013 03:08 by dc59.
28 Mar 2013 00:52 - 28 Mar 2013 03:08 #8165 by dc59
Delete
28 Mar 2013 02:31 #8166 by Mullson
Replied by Mullson on topic skyartec compatibility
Wats the picture? This project is for everyone and all. fer more the first thing this jittering is FK distrusting.The first explanation was correct, I got it right the first time whith PBs explination and some thinking and sens This is no do it your self club.
Lets come together and make some sense!
28 Mar 2013 02:41 #8167 by dc59
Mullson wrote: Wats the picture? This project is for everyone and all. fer more the first thing this jittering is FK distrusting.The first explanation was correct, I got it right the first time whith PBs explination and some thinking and sens This is no do it your self club.
Sorry!
If I uploaded any picture with no sense,please let me know,I will delete it.
do you mean the connection table or devo10 pictures?
28 Mar 2013 03:05 - 28 Mar 2013 03:05 #8169 by PhracturedBlue
Replied by PhracturedBlue on topic skyartec compatibility
vlad_vy wrote: PA_EN: When Tx status set '1', Rx set '0'
No, they can both be enabled at the same time. the PA_EN powers up the power-amp (transmit amp). The LNA_EN powers up the low-noise-amplifier (receiver amp). It is perfectly valid for both to be enabled simultaneously though it does draw more power that way. Since we don't have enoiugh pins to actually manage these connections, tying them always on is what I've done. It is possible it will reduce the overall performance of the CC2500 module, but I haven't really tested yet. Note that this has nothing to do with the CC2500. These connections are (as far as I'm aware) only for controlling the external amplifier
Last edit: 28 Mar 2013 03:05 by PhracturedBlue.
28 Mar 2013 03:16 #8172 by Hexperience
dc59 wrote: Delete
DC59!!! Those pictures were great! I don't have a clue what that guy was talking about. Please repost them!
28 Mar 2013 03:19 #8174 by PhracturedBlue
I have updated the table in the pdf so that it is hopefully correct now.
28 Mar 2013 03:22 #8175 by Hexperience
Does the XL2500 not have a Low Noise Amp? Will that be a problem? Specifically I'll be looking for long range (with telemetry when we get to that point).
28 Mar 2013 03:23 #8176 by sbstnp
Replied by sbstnp on topic skyartec compatibility
Hexperience wrote:
dc59 wrote: Delete
+1. Mullson seems to be... special :), don't listen to him
Devo 10 + 4in1
Spektrum Dx9
FrSky Taranis + TBS Crossfire
28 Mar 2013 03:25 - 28 Mar 2013 03:27 #8177 by sbstnp
Hexperience wrote: Does the XL2500 not have a Low Noise Amp? Will that be a problem? Specifically I'll be looking for long range (with telemetry when we get to that point).
The one I got has both PA and LNA.
www.aliexpress.com/item/CC2500-PA-LNA-wi...-2-4G/359941652.html
Which XL2500 is yours, D02 or D03?
From what I'm seeing around:
D02: both PA and LNA, 20dbm
D03: just PA, 15dbm or 16dbm
Devo 10 + 4in1
Spektrum Dx9
Last edit: 28 Mar 2013 03:27 by sbstnp.
28 Mar 2013 03:26 #8178 by Hexperience
vlad_vy wrote: I think it will be:
Thanks Vlad!!! Just what I needed.
28 Mar 2013 03:32 - 28 Mar 2013 03:52 #8179 by Hexperience
%@#$%@%%!!! I hate ebay! :)
Yes, I have the D03 but the ebay listing said it was 20dbm... Now I have to order again and wait... crud.
Thanks for catching that sbstnp.... I wouldn't have known...
edit--- AHHH I just did it again... I just ordered from the link posted above without reading it. It says it's 17dbm and "work distance" is 800m (But that it's up to 150ma so I don;t know...)
Lucky these things are cheap! I'll have a nice collection by the end. ;)
I'll hook up the xl2500-d03 for now...
Last edit: 28 Mar 2013 03:52 by Hexperience.
Time to create page: 0.995 seconds
