Protocol select on original software
- Pattaya01
04 Jun 2013 10:02 #10552
by Pattaya01
Protocol select on original software was created by Pattaya01
Would it be possible to add protocols without having to load the Deviation software?
The reason I am asking is this: I have the Devo12S and the Deviation software is still not ready or in a premature state. But I would love to use my old Spektrum receivers (I have a bunch) with my Devo12S.
So adding a button for example in the system menu where I could choose the protocol.
04 Jun 2013 10:14 #10553
Replied by rbe2012 on topic Protocol select on original software
Deviation 3.0.0 is ready for and supports the Devo12, but does not make use of the big screen (only a 320x240-sized window more or less). If you can live with this, you can fly your Spektrum rxs with your Devo12.
Otherwise there is no chance to make changes to the original software because the source code is not available (it's not open source like deviation is).
- Pattaya01
04 Jun 2013 10:21 #10554
by Pattaya01
Replied by Pattaya01 on topic Protocol select on original software
I thought you guys can hack into anything....
Seems I have to wait for your work to be finished then. Let's get on with it.
- domcars0
04 Jun 2013 12:42 - 04 Jun 2013 12:43 #10556
by domcars0
Replied by domcars0 on topic Protocol select on original software
Hack the Pentagon information system would be easierPattaya01 wrote: Would it be possible to add protocols without having to load the Deviation software?
Last edit: 04 Jun 2013 12:43 by domcars0.
Time to create page: 0.190 seconds
- Protocol select on original software
