What about Assan?
- goebish
- NRF Weirdo
08 Jan 2017 13:08 #57694
by goebish
Replied by goebish on topic What about Assan?
Ok, please check with an older version again to make sure there's a problem then fill a bug report:
www.deviationtx.com/wiki/reporting_bugs
- goebish
- NRF Weirdo
08 Jan 2017 13:15 #57695
by goebish
Oops, seems the Mantis bug tracker is down ...
Maybe you can open a thread for your issue here:
www.deviationtx.com/forum/7-development
- TF824
08 Jan 2017 13:43 - 08 Jan 2017 13:55 #57698
by TF824
Replied by TF824 on topic What about Assan?
V5.0.0-f395b75 was showing same message but I was focusing ASSAN binding so ignored that messages just pushed ENT to proceed that time,,,
I think V5.0.0-3fabab4 was not showing this message but of course ASSAN X8R6 and X8R7 were not binding.
Like you said CC2500 note on the Banggood.com saying
''For Devo7e, there may be a warning that says ‘Missing modules’ , when you turn on transmitter. to solve it ,you can turn off transmitter and then turn on it again. The reason is that Devo7e’s power supply is very limit, it’s maybe not ready at the beginning.
But I'm just wondering why deviation 5.0.0 didn't show this message at all for long time since I installed CC2500 about 6 month ago but it started once installed different version deviation,,,,
Thanks.
Thanks.
Last edit: 08 Jan 2017 13:55 by TF824.
- goebish
- NRF Weirdo
08 Jan 2017 13:46 #57699
by goebish
Sorry, but I do not have a 7e nor a cc2500 module, you should open another topic to check if other users are having the same issue.
- TF824
20 Jan 2017 13:40 - 20 Jan 2017 13:43 #58237
by TF824
I fixed ''Missing module'' by adding voltage regulator.
www.deviationtx.com/forum/3-feedback-que...ssing-modules-cc2500
Thanks goebish, You were right, it was not enough power from original power supply.
Now I have another question about ASSAN protocol again.
I just tried to test my Align DS525M (Pulse 1520μs) servo accidentally and found strange issue.
When I move stick very very slowly, ASSAN RX keeps binding and servo moves all the way, but if I move stick quick(Actually not so quick say normal stick move, ASSAN start red blinking and loose binding.
If I use other STD digital servo like Futaba S3151(Also Pulse 1520μs) etc, this never happen.
Any idea why this happen?
Last edit: 20 Jan 2017 13:43 by TF824.
20 Jan 2017 19:02 #58251
Replied by FDR on topic What about Assan?
What kind of battery do you use?
May be on a quick movement the servo takes too high current, and causes a brown out...
- goebish
- NRF Weirdo
20 Jan 2017 19:36 #58253
by goebish
I agree, I bet on weak power supply, again
- TF824
21 Jan 2017 00:34 #58261
by TF824
My bad,,,,,
You guys are right, It was just a weak regulator for RX power.
Changed to better regulator and all are good!!
Thanks.
Thanks.
- Maco33
20 Mar 2018 10:19 #68222
by Maco33
Replied by Maco33 on topic What about Assan?
Hellou, the Assan X8R6 (black) receiver is not binding for me . When binding the receiver is blinking red led, when binded DEVO 7e makes a sound, led's are blinking red and green. It's not working after removing battery and bind plug and reattaching battery. I get blinking red and green led.
I have instaled DEVO_5.0.0-658a6f2 fw.
Help me pleas.
L.
Help me pleas.
L.
- Bisky
22 Mar 2018 14:48 #68279
by Bisky
PM m8.
Devo F7 XMS + 4in1 module
Replied by Bisky on topic What about Assan?
Maco33 wrote: Hellou, the Assan X8R6 (black) receiver is not binding for me . When binding the receiver is blinking red led, when binded DEVO 7e makes a sound, led's are blinking red and green. It's not working after removing battery and bind plug and reattaching battery. I get blinking red and green led.
Help me pleas.
L.
PM m8.
- Bisky
23 Mar 2018 08:08 #68305
by Bisky
Tested today, both work with ASSAN:
deviation-devo7e-256-v5.0.0-91beb1b =>3in1 module
deviation-devof7-XMS-v5.0.0-91beb1b =>nrf24l01
- Maco33
25 Mar 2018 07:12 - 25 Mar 2018 10:47 #68345
by Maco33
....and which is for DEVO7e - nrf24l01 module?
I tested different night builds and still does not work
I'll wait for module 3in1, will try and then write
L.
L.
Last edit: 25 Mar 2018 10:47 by Maco33.
- Maco33
08 Jul 2018 15:42 #69815
by Maco33
Hello, so I bought this module "DEVO Transmitter Tuner Modified NRF24L01" and everything is OK now. Thanks for the help.
M.
M.
Time to create page: 0.627 seconds
- What about Assan?
