18 channels for DSM2 / DSMX ?
- Cesco
29 Oct 2013 11:13 #15121
by Cesco
Replied by Cesco on topic 18 channels for DSM2 / DSMX ?
I got my "latency test" firmware running, but i get strange results on previous firmware (not the one you deleted).
I get 22ms on every x-channel.
Now its easily possible that my latency measurement is wrong.
29 Oct 2013 11:16 - 03 Nov 2013 06:01 #15122
Replied by vlad_vy on topic 18 channels for DSM2 / DSMX ?
Corrected firmware
DELETED
DELETED
Last edit: 03 Nov 2013 06:01 by vlad_vy.
- Cesco
29 Oct 2013 12:00 - 29 Oct 2013 12:10 #15124
by Cesco
channels numbered 0 to 7
8 xchannels 88ms
7 xchannels 88ms chan 7 missing
6 xchannels 66ms chan 3 , 7 missing
5 xchannels 66ms chan 3 , 6 , 7 missing chan 0 , 4 , 1 , 5 , 2 working
4 xchannels 44ms chan 2 , 3 , 6 , 7 missing chan 0 , 4 , 1 , 5 working
3 xchannels 44ms chan 5 , 2 , 3 , 6 , 7 missing chan 0 , 4 , 1 working
2 xchannels 22ms chan 1 , 5 , 2 , 3 , 6 , 7 missing chan 0 , 4 working
1 xchannels 22ms chan 4 , 1 , 5 , 2 , 3 , 6 , 7 missing chan 0 working
This is good, but ...
why this 0 4 1 5 2 sequence and not 0 1 2 3 4 ?
8 xchannels 88ms
Last edit: 29 Oct 2013 12:10 by Cesco.
29 Oct 2013 13:08 - 29 Oct 2013 13:37 #15127
Is it for last firmware? I don't quite understand, all 8 x-channels are in working state?
The sequence 0 4 1 5 2 6 3 7 - it's because for first packet = 0 1 2 3 and for second packet = 0+4 1+4 2+4 3+4 (0 1 2 3). If I do not change counter for second packet, it's normal sequence. With optimal arrangement it always will be not in series.
If you test previous firmware, you will find 0 1 2 3 4 5 6 7, but only first 3 x-channels have delays 22ms, 44ms, 66ms, and all others have delay 88ms.
If you will look in capture from DX18, it's not in series.
Last edit: 29 Oct 2013 13:37 by vlad_vy.
- Cesco
29 Oct 2013 13:38 #15128
by Cesco
Last firmware, yes.
Everithing works how it should, all ok.
I PM you where to get access to my DX18QQ test person.
vlad_vy wrote: Is it for last firmware? I don't quite understand, all 8 x-channels are in working state
Last firmware, yes.
29 Oct 2013 13:43 #15129
If you have tested your software with DX18 and software works with DX18 and Devo12, it seems we got working version.
- Cesco
29 Oct 2013 13:46 #15130
by Cesco
I guess so
vlad_vy wrote: If you have tested your software with DX18 and software works with DX18 and Devo12, it seems we got working version.
I guess so
29 Oct 2013 13:50 #15131
Last question, what will be best, last firmware with optimal delays or previous firmware with x-channels in series (0 1 2 3 4 5 6 7)?
- Cesco
29 Oct 2013 15:47 #15133
by Cesco
Last firmware
After some thinking i know the reason for the channel sequence.
You are right, it must be this way !
Good work
Good work
29 Oct 2013 16:58 - 30 Oct 2013 04:40 #15134
The X-Plus channels structure
Channel numbers 0 to 11 are normal, with data resolution 11bit (2048).
Channel 12 carries the X-Plus channels, with data resolution 9bit (512).
Channel transfer structure:
packet 1 -> 1 5 2 4 6 10 12
packet 2 -> 0 7 3 8 9 11 12
X-Plus data format
each 16bit X-Plus data value is defined as:
a bbbb cc ddddddddd
a: always 0
bbbb: the channel number, always 12
cc: X-Plus channel number, low 2 bits, third bit defined by packet number, 1st packet = 0, second packet = 1
dd..: X-Plus channel data, 9 bits, 256 is midpoint
The channel data will be 0xffff if the specific X-Plus channel slot is unused.
1 to 2 X-Plus channels, every 22ms
3 to 4 X-Plus channels, every 44ms
5 to 6 X-Plus channels, every 66ms
7 to 8 X-Plus channels, every 88ms
X-Plus data format
a bbbb cc ddddddddd
a: always 0
Last edit: 30 Oct 2013 04:40 by vlad_vy.
30 Oct 2013 06:22 #15141
Cesco, I have new idea. If you can bind/test your software with DSM2 1024 mode and DX18, I can build firmware with X-Plus for DSMX and DSM2 (1024). I think it will work also.
- Cesco
01 Nov 2013 10:51 #15190
by Cesco
I can see how x-chan can work with DSM2 2048. Tell me if you have a version.
But dsm2 1024 ? The cahnnel field is wrong.
01 Nov 2013 11:24 #15191
Now I think you are right. It's unlikely that X-Plus 8 module can decode two different channel fields.
In that case we need wait next release. After that will be possible to implement 1024/2048 switching for DSM2 protocol.
01 Nov 2013 12:20 - 01 Nov 2013 12:22 #15192
Replied by rbe2012 on topic 18 channels for DSM2 / DSMX ?
For testing simply add one line in dsm2.c and you get Model.proto_ops[1] Model.proto_opts[1]=0 for 1024 and =1 for 2048:You can use it where needed.
static const char * const dsm_opts[] = {
_tr_noop("Telemetry"), _tr_noop("Off"), _tr_noop("On"), NULL,
_tr_noop("Resolution"), _tr_noop("Steps: 1024"), _tr_noop("Steps: 2048"), NULL,
NULL
Last edit: 01 Nov 2013 12:22 by rbe2012.
01 Nov 2013 17:19 - 01 Nov 2013 17:19 #15204
Last edit: 01 Nov 2013 17:19 by vlad_vy.
01 Nov 2013 17:36 #15205
The protocol options are not conditional. You can set them to any value in any case.
It is part of the code to decide if it's used. Maybe we can show an explanation or hint near the option, but it has to fit in the first field of the array (resp. on the screen where it is located actually and not hidden behind the value box).
- Cesco
01 Nov 2013 20:39 #15209
by Cesco
If we could use 1024 OR 2048 in DSM2 this would be great.
Also maybe "enable x-channels" or not. Auto gray if 1024 selected.
You guys aware this could be a big thing with truck / boat people?
02 Nov 2013 07:55 - 03 Nov 2013 07:28 #15218
It seems all issues solved. But it required thorough testing.
Cesco, can you test all modes: < 8 channels (1024), > 7 channels (1024), > 7 channels (2048), X-Plus cnannels?
At protocol options page you can select all you want, but:
1) if you have number of channels < 8, next time you visit protocol options page you will see 'DSM2 resolution' = 'Steps: 1024';
2) before you can get number of channels > 12 you have to select 'X-Plus channels' = 'On';
3) if you select 'X-Plus channels' = 'On', number of channels > 7, next time you visit protocol options page you will see 'DSM2 resolution' = 'Steps: 2048', you don't need select it manually, it will change automatically;
4) X-Plus channels started from 13 channel (X-Plus 1), 14 channel (X-Plus 5), 15 channel (X-Plus 2), 16 channel (X-Plus 6), and so on.
For DSMX protocol resolution is always 11bit(2048).
Firmware for Devo12, based on v3.1.0-beta-04 rbe2012 build
DELETED
Devo12 filesystem
DELETED
DELETED
Devo12 filesystem
DELETED
Last edit: 03 Nov 2013 07:28 by vlad_vy.
02 Nov 2013 09:34 #15224
I think you can force the right values to be shown directly, not only after revisiting the page. I'll have a look later.
vlad_vy wrote: I1) if you have number of channels < 8, next time you visit protocol options page you will see 'DSM2 resolution' = 'Steps: 1024';
02 Nov 2013 11:03 - 03 Nov 2013 07:28 #15226
RBE, I can provide you changed files, if needed (protocol\dsm2.c, protocol\interface.h, target\devo12\target_defs.h)
DELETED
DELETED
Time to create page: 1.027 seconds
- 18 channels for DSM2 / DSMX ?
