Protocols, Chips and Hardware
- enderffx
- HappyHarry
29 Nov 2013 16:38 #16049
by HappyHarry
Replied by HappyHarry on topic Protocols, Chips and Hardware
do you have a link? i purchased my nrf24l01+ from banggood.com here >>
www.banggood.com/DEVO-Transmitter-Tuner-...ys-V922-p-89812.html
much cheaper than $20 and it works perfectly with my FBL80
- enderffx
29 Nov 2013 16:39 #16050
by enderffx
Replied by enderffx on topic Protocols, Chips and Hardware
Ooops, i am sorry.
www.banggood.com/NRF24L01-+-2_4G-Wireles...Arduino-p-80577.html
Thats the one...
Ender
Thats the one...
Ender
- HappyHarry
29 Nov 2013 16:46 #16051
by HappyHarry
the one i linked is better, as it has a power amplifier to increase the range, and also the antenna can be placed inside the 7e next to the existing antenna no problems. also here are some links to the 7105
easy-taobao.com/taobao/view/id/2682594502
www.ebay.com/itm/A7105-2-4G-Wireless-Mod...&hash=item27d99abf7c
and the better nrf24l01 option
- enderffx
29 Nov 2013 16:50 - 29 Nov 2013 16:51 #16052
by enderffx
@Harry,
that A7105 you posted NOW is a third of the price !
But doesnt it lack the needed amplifier ?
Or does the 7E do the job of amplifying the signal.
OMG confused again
Ender
OMG confused again
Ender
Last edit: 29 Nov 2013 16:51 by enderffx.
- HappyHarry
29 Nov 2013 17:11 #16056
by HappyHarry
i can't find a link to a A7105 with a power amp sorry, maybe someone else has a link to one? and i'm not sure how much range you will get without a power amp on the A7105 as i don't use one, but surely it will be enough to fly a hubsan x4 far enough away that you couldn't see which way it was pointing as it's very small lol so i think you will be fine without an amp for the 7105
but for the nrf24l01 i will be flying a hisky HCP130 when it comes out so i think the power amp is needed for it
- enderffx
29 Nov 2013 17:29 #16059
by enderffx
Ooops, istnt THIS the one with PA ?
www.ebay.de/itm/120970651459?ssPageName=...id=p3984.m1423.l2649
Greetings,
Ender
Greetings,
Ender
- HappyHarry
29 Nov 2013 17:56 #16064
by HappyHarry
no that has no PA, but it's maximum range is 260m, and like i said before if you flew a hubsan x4 260m away you'd be lucky still to see it so the A7105 without the PA should be more than enough
- victzh
29 Nov 2013 18:04 #16066
by victzh
Replied by victzh on topic Protocols, Chips and Hardware
It does have PA, not extremely powerful though. It is listed as 10dBm, which means 10mW output, not 1mW (0dBm) which is totally without PA, and not 100mW (20dBm). As the distance depends on power as square root, extra 10dBm is approx 3 times the distance.
- HappyHarry
29 Nov 2013 19:49 #16074
by HappyHarry
there you go ender, it does have an amp
thanks for the info victzh
- enderffx
29 Nov 2013 21:23 #16075
by enderffx
Guys, thanks for helping me out.
I now know which modules to buy, both seem to be available around $12 USD...
I did not get the PA thing before as i thought the signal is still amplified and transmitted by the EVO.
But now i guess if i have 2 modules i have / need 3 Antennas, 1 for the Devo, one for each module, right ?
So the Devo acts "just" like a programmable "gamepad" for the modules, right ?
Greetings,
Ender
Greetings,
Ender
- victzh
29 Nov 2013 22:00 #16076
by victzh
Yes, you need three antennas. I don't understand completely your reference to gamepad. Devo holds and handles protocol code, modules are just dumb RF chips with amplifiers. It is possible to wire modules with RF switches so that you need only one antenna, and probably eventually we get there, but now it appears to be OK just put them inside the Devo's body, or pass it into antenna case - it is wide enough to hold at least couple of this coax antennas.
- HappyHarry
29 Nov 2013 23:21 - 29 Nov 2013 23:21 #16077
by HappyHarry
no problem ender, enjoy your multi protocol 7e
Last edit: 29 Nov 2013 23:21 by HappyHarry.
- enderffx
30 Nov 2013 11:39 #16089
by enderffx
Well... thank you guys again, i ordered my stuff which will probably take forever and a day
I'll try to figure out the rest by myself but i won't be sure that i bug you again
Greetings from Germany...
Ender
Ender
- WheresWaldo
04 Dec 2013 03:48 #16255
by WheresWaldo
Replied by WheresWaldo on topic Protocols, Chips and Hardware
Got my module yesterday, soldered pigtails to each of the eight pins. Problem now is I am trying to see if anyone has any documentation on adding this module to a Devo10. I found tones of stuff about the Devo7 but I am stumped trying to find someone or some documentation on adding the module to the 10.
If anyone can help I would greatly appreciate it.
- HappyHarry
04 Dec 2013 12:11 #16269
by HappyHarry
have you looked at the howto >>
deviationtx.com/repository/Documentation...uleInstallation.pdf/
- WheresWaldo
04 Dec 2013 13:39 #16274
by WheresWaldo
Looked at it 100 times only shows the devo7. The pinouts of the module are well documented, the devo10 isn't.
HappyHarry wrote: have you looked at the howto >> deviationtx.com/repository/Documentation...uleInstallation.pdf/
04 Dec 2013 13:56 #16275
Replied by PhracturedBlue on topic Protocols, Chips and Hardware
Waldo, that is because the devo8 and Devo10 procedure is identical, so the devo8 instructions should match what you need.
- WheresWaldo
04 Dec 2013 15:08 #16276
by WheresWaldo
- enderffx
05 Dec 2013 11:06 #16294
by enderffx
Hi again !
Hmm, there was some talk hee about modules havin an on-board PA or not.
What do you think: If i buy one of those cheapo A7105 with Antenna on the PCB...
This ought to have no or a very low power PA, right ?
BUT if i connect the Antenna out to a 2W 2,4GHz Booster that shouldn't matter, right ?
Thats the booster i got:
Booster 2W
Or do you think the power is too low even as input for such a Booster ?
(I am asking as i have one of these boosters anyways so i could save a few bucks for the A7105 module).
Greetings,
Ender
Booster 2W
Greetings,
Ender
Time to create page: 0.792 seconds
- Protocols, Chips and Hardware
