Ares Ethos Quadcopter
16 Feb 2014 01:40 - 16 Feb 2014 14:24 #20338 by John-Boy
Ares Ethos Quadcopter was created by John-Boy
Found... ;)
Use the YD717 protocol, the reverse the ailerons, then fly!
Thanks to all.... :)
John L.
Hi there,
Anyone know the protocol for the Ares Ethos Quads? The have several small airplanes and a new larger quad with missle launcher and accessories.
Thanks in advance.... ;)
John L.
Last edit: 16 Feb 2014 14:24 by John-Boy.
16 Feb 2014 07:53 #20347 by SeByDocKy
Replied by SeByDocKy on topic Ares Ethos Quadcopter
John-Boy wrote: Hi there,
John L.
Probably using a FrySky protocol since they seem to be som WLtoys repackaged quads. In this case, you need the A7105-500 RF chip in your devo
16 Feb 2014 16:27 #20366 by hexfet
Replied by hexfet on topic Ares Ethos Quadcopter
John-Boy wrote: Found... ;)
Interesting! Frame looks very much like the YD717, though the motor holders are a little different.
I just got a second YD717 which has a slightly different flight controller board than my first one. It looks like the same board that's in the Ares 75 I saw online, except the motor wires are soldered instead of using connectors like the Ares.
10 Apr 2014 03:31 #22301 by hexfet
John-Boy wrote: Use the YD717 protocol, the reverse the ailerons, then fly!
When you reversed the ailerons for the Ares Ethos, did you notice a difference in the roll rate versus the pitch rate? Or do aileron and elevator work about the same?
I'm working on a change to support the XinXun, which flys fine with rudder reversed but has very slow yaw rate. I'm concerned the fix for that may break the Ares if the Ares has the same pitch and roll rates with aileron reversed.
Thanks,
hex
Time to create page: 0.686 seconds
