Hubsan X4 with DEVO 12S
- sv650s
09 May 2014 10:04 #23062
by sv650s
Hubsan X4 with DEVO 12S was created by sv650s
i'm a newbie with DEVO12S……
and i'm totally lost with the modifications to make on my DEVO 12S
I have got a Hubsan X4 and i would like to control it with my DEVO 12S
I know i need a A7105 module (i have it) to put into the radio
So have you got a photo or tutorial for how to connect the A7105 module into the DEVO 12S ?
After i know i need to make modifications in firmware of the DEVO 12S and install DeventionTX
But i don't understand how to make it, i'm afraid to make mistake, so witch modifications i must do in firmware of DEVO 12S ? How to install Devention TX ? have you got a step to step, tutorial or other ?
Sorry for my bad englishe, i'm french….
Thanks very much for your help
- victzh
09 May 2014 15:21 #23069
by victzh
Replied by victzh on topic Hubsan X4 with DEVO 12S
On your left, in a menu cryptically named "User Manuals" there are ... User Manuals, and among them - ModuleInstallation.pdf
Check it first, if you have further questions, don't hesitate to ask.
www.deviationtx.com/user-manual/Document...uleInstallation.pdf/
With firmware - you need to replace it with Deviation firmware, which is totally different from the original one. The process is also described in www.deviationtx.com/user-manual/Document...tion8UserManual.pdf/
- sv650s
09 May 2014 17:25 #23073
by sv650s
Replied by sv650s on topic Hubsan X4 with DEVO 12S
And it´s all ?
No other modifications to make for hubsan x4 ?
- victzh
09 May 2014 18:16 #23074
by victzh
What else did you expect? Solder a module, replace firmware, grab a model file for your model from this forum.
- sv650s
09 May 2014 21:38 #23086
by sv650s
The firmware procedure is the same for devo 12S as for devo 8S ?
- victzh
09 May 2014 21:49 #23087
by victzh
About this I am not totally sure. I recall vague mentions of "library", which is 12-specific. How about the document? Are there any words in it? It's combined Devo6/8/12 manual. There is a French version in the same place, by the way.
- sv650s
10 May 2014 08:05 #23106
by sv650s
I'm afraid to make mistakes !
- sv650s
10 May 2014 13:09 #23114
by sv650s
Witch devention dfuse i must download for my devo 12S
www.walkera.com/en/updater.php
The V2 or V1.7 marked for devo12S....
I think i must download the V2 but it´s not marked for devo12S
Thanks for your help
10 May 2014 13:34 - 10 May 2014 13:34 #23115
Replied by PhracturedBlue on topic Hubsan X4 with DEVO 12S
Yes, use V2. It works fine with the Devo12S
Last edit: 10 May 2014 13:34 by PhracturedBlue.
- sv650s
10 May 2014 21:49 - 11 May 2014 09:07 #23121
by sv650s
I'm sorry but i'm not sure where to solder the A7105 module ....
I have understand the solders on the module, but i'm not sure where to solder it on the radio.....
Have you got a photo of the soldering points in the devo 12S please ?
And one last thing, There is 2 schemas for the A7105..... Witch is the good ???
This one is from tutorial of devitation's site : www.deviationtx.com/repository/Documenta...uleInstallation.pdf/
This one is from one post of deviation's forum :
www.deviationtx.com/media/kunena/attachm...oduleTablePage10.jpg
Last edit: 11 May 2014 09:07 by sv650s.
- sv650s
15 May 2014 15:45 #23262
by sv650s
Now i would to know how can i have the frequencies choice and telemetry on my Devo 12S for my hubsan H107D ?
I'm confuse in all the posts concerning this ....
Again tanks for your help
Time to create page: 0.591 seconds
- Hubsan X4 with DEVO 12S
