JD 395 cx-10
- SeByDocKy
- SeByDocKy
11 Aug 2014 19:12 #25157
by SeByDocKy
Replied by SeByDocKy on topic JD 395 cx-10
Can you compile for the Devo 7E too ? I guess there will be some other testers owning the Devo 7E
- billmester
11 Aug 2014 19:18 #25158
by billmester
Replied by billmester on topic JD 395 cx-10
...and some interesting info:
if i turn on both quads, and then run the binding sequence, both will fly the same time
so the binding does not have unique pairing code...
- btoschi
11 Aug 2014 20:00 #25159
by btoschi
Replied by btoschi on topic JD 395 cx-10
This means that the receiver on the quad does not propagate any ID back.
This is common with many RC-toy protocols.
Still the transmitter can choose an individual ID per session (random or per TX) - often affecting RX/TX Address (think of "MAC-Address") and / or RF Channel(s) it sends on.
And can you please clarify: You've paired using original Transmitter ?
- billmester
12 Aug 2014 14:58 #25174
by billmester
YES.
1. turn on quad 1
2. turn on quad 2
3. turn on original tx
4. binding process (up-down)
5. both stop blinking, both fly
1. turn on quad 1
2. turn on quad 2
- billmester
- SeByDocKy
12 Aug 2014 16:20 #25177
by SeByDocKy
The red board is using the skywalkr protocol ....
Now it's the green edition Under investigation
billmester wrote: both RED BOARD
- djzinc
16 Aug 2014 19:34 #25221
by djzinc
Replied by djzinc on topic JD 395 cx-10
I know is not exactly on topic, but also I, did the "synchro dance" with 3*V272.
And the reason could be: all this new micro quads, regardless the shape, all are kind of the same conception (clones, clones of clones, etc). So, would not be a surprize also for the CX-10s to behave like a "swarm". Which is not bad atoll, it's quite funny
- skyjet
16 Aug 2014 19:48 #25222
by skyjet
Replied by skyjet on topic JD 395 cx-10
I have a red board CX 10 and a Devo 10. I can find "YD717" but I can't find the "Sky Wlkr" option. Does anybody have the programming file for the CX 10 for a Devo 10?
- billmester
16 Aug 2014 20:31 #25223
by billmester
Same with me (at the moment). Seems that 4.0.1does not contain it yet. Upgrading now...
- skyjet
16 Aug 2014 21:11 #25225
by skyjet
I friend of mine did the mods for me. I have V4.0.1. Is this the latest?
billmester wrote: Same with me (at the moment). Seems that 4.0.1does not contain it yet. Upgrading now...
- billmester
16 Aug 2014 21:15 #25226
by billmester
latest RELEASED version. there are "nightly builds" with plenty of upgrades
- skyjet
16 Aug 2014 21:17 #25227
by skyjet
Please let me know if you get the SkyWlr after the update!
billmester wrote: latest RELEASED version. there are "nightly builds" with plenty of upgrades
- billmester
16 Aug 2014 21:21 #25228
by billmester
stuck with the update...
see the topic: FW upgrade - TX not seen in DFU, only as USB drive
- djzinc
17 Aug 2014 17:04 #25247
by djzinc
I've done the update o NB of 2014.08.01 (deviation-devo7e-v4.0.1-92e1705) and it has "Sky Wlr". To select it, first highlight the YD717 as protocol, then press ENT. Here, in the subselection, you can choose: "YD717", "Sky Wlr" or "XinXun".
- billmester
17 Aug 2014 18:17 #25249
by billmester
Done it again, now it works. Have no idea, what happened first time
RED CX-10's are flying nicely now
One question left: how to make the flips?
bm
bm
- SeByDocKy
19 Aug 2014 09:56 #25289
by SeByDocKy
assign Channel5 on a switch
billmester wrote: Done it again, now it works. Have no idea, what happened first time
bm
- billmester
19 Aug 2014 18:46 - 20 Aug 2014 20:24 #25296
by billmester
Edit: WITH updated .ini
OK... aaaand?
What should I program to the switch?
What action is equivalent to the button press + direction move?
This is my .ini so far, works well, only need the flip to work...
OK... aaaand?
Last edit: 20 Aug 2014 20:24 by billmester.
- billmester
20 Aug 2014 20:35 - 21 Aug 2014 13:56 #25311
by billmester
So - I got it to work.
BIIIG thanks to SeByDocKy.
Now I can use the flip function like this:
-flip GEAR switch to 1
-do the flip with a FULL movement of the AIL or ELE
-flip GEAR switch back to 0
Notes:
-If I leave GEAR in 1, then I can make 2-3 flips then no more... need to switch back to 0 always for 100% sure flips
-If I use decreased range ("beginner mode", see the .ini file above), it will work only randomly or not at all... need to use the full range for flips
-Flips are sensitive to TRIM. If you are using too big trims, flips may not happen
bm
Notes:
bm
Last edit: 21 Aug 2014 13:56 by billmester.
- victor123s
04 Sep 2014 05:00 #25489
by victor123s
Replied by victor123s on topic JD 395 cx-10
Hi, I have Devo7e with 2 3pos extra switches and CX10 green board. All CX10 sold here in Thailand, as far as I had seen are green board version. I'm itchy to test the new protocol. How close are you guys at cracking it?
Time to create page: 1.108 seconds
- JD 395 cx-10
