KN protocol adaption for Feilun helicopter?
10 Jun 2015 15:24 #33773 by victzh
Replied by victzh on topic KN protocol adaption for Feilun helicopter?
Moeder wrote: I guess developers always think simple...
Ho-ho, tell it to people who reversed DSMX! And even couple of protocols I reversed - V202 and SLT required some serious effort.
10 Jun 2015 15:28 #33774 by victzh
Replied by victzh on topic Help needed - Randomizing TXID
You probably generate the TX id which is beyond of range of acceptable ids. If the id is 4 bytes it does not mean all the values are legal. It happened in several protocols already. Try to use the TX id from Deviation directly to find boundaries of this range.
10 Jun 2015 15:40 - 10 Jun 2015 15:44 #33775 by Moeder
Replied by Moeder on topic KN protocol adaption for Feilun helicopter?
I didn't mean to insult anybody, I was merely laughing at the "complex" algorithm the KN-developers used. Even I managed to think of that ;-)
I will see what I can find out about the TXID-limits. Attached is a link to the logic data for anyone interested.
FX071C Power up and bind
Last edit: 10 Jun 2015 15:44 by Moeder.
10 Jun 2015 20:26 - 11 Jun 2015 09:01 #33802 by Moeder
Replied by Moeder on topic KN protocol adaption hopefully working now
I belive I have it sorted out now...attached files for devo7e and devo10 based on the current nightlys as well as updated ini files for both (FMOD controls 3g/6g gyro now, SW A or RUD D/R controls the original FX dual rate). This version generates a random ID bases on the deviation ID you are setting. In the unlikely case of an ID not working (or incomplete), please try a couple of others.
P.S.: timestamps on files are off by almost 24h as my virtual box linux has the wrong time... :whistle:
edit: updated files available. source code updated as well.
Last edit: 11 Jun 2015 09:01 by Moeder. Reason: updated files and added binaries for other devo transmitters
10 Jun 2015 20:57 #33805 by victzh
Moeder wrote: I didn't mean to insult anybody
And you did not. I also just wanted to emphasize that we're lucky that designers of recent avalanche of protocols are pretty unimaginative. There are so many ways to complicate the job of reverse engineer!
11 Jun 2015 06:53 - 11 Jun 2015 06:53 #33816 by Moeder
Very true. I was really amazed when I first learned about the deviation project, you guys did a hell of a job. Now that the repository get's straighted out again trying to merge all the different patches I believe it will make yet another leap forward. I hope I can contribute just a little bit. When do you think is the right time to make a pull request?
Last edit: 11 Jun 2015 06:53 by Moeder.
11 Jun 2015 08:48 #33817 by Flyingboats
Replied by Flyingboats on topic KN protocol adaption for Feilun helicopter?
Awesome work Moeder. Successfully bound the Devo 10 and flew FX71 with your previous file. Will download and update with your latest now :)
And Victzh and Amax thanks for all the inputs. Us techno-retards really appreciate the online community with the contribution you guys all make. The Deviation project is awesome and it's a delight to fly our models with so much control at our fingertips.
I've been getting emails all afternoon from a fellow rc'er who we get setup with a Devo 10 a couple of weeks ago excited that he'll be able to fly his FX birds with a decent radio finally. Thanks guys B)
11 Jun 2015 09:04 - 11 Jun 2015 09:05 #33818 by Moeder
Good to hear! If the current code works we should be all set. That should allow plenty of FX's flown at the same time. Tell me if you experience any glitches, there is alway room for some improvement.
Flyingboats wrote: Awesome work Moeder. Successfully bound the Devo 10 and flew FX71 with your previous file. Will download and update with your latest now :)
Last edit: 11 Jun 2015 09:05 by Moeder.
11 Jun 2015 09:04 #33819 by Flyingboats
Loaded and initially tested 2nd version. Tried rebinds, powering heli and Tx off and on, plus have changed Bind ID, all good so far.
Winter's evening here, family in front of the fire, threats of divorce if I fly in the living room :P
11 Jun 2015 09:07 #33820 by Moeder
Flyingboats wrote: Winter's evening here, family in front of the fire, threats of divorce if I fly in the living room :P
Shouldn't risk that, you may need someone to give you mental support the next time you crash a 450 ;-)
11 Jun 2015 09:12 #33821 by Flyingboats
If there's enough financial support I can cope without the mental support!
11 Jun 2015 10:03 #33823 by Moeder
Replied by Moeder on topic Icon for FX071C
A first icon can be found here .
Time to create page: 0.063 seconds
