WLToys V912/V915/? protocols
20 Mar 2015 22:27 #29968 by PhracturedBlue
Replied by PhracturedBlue on topic WLToys V912/V915/? protocols
Are you using the latest repo from:
bitbucket.org/deviationtx/deviation
what version of gcc do you have?
there is a '#pragma weak' which can cause issues with older gcc. It should happen at link time not compile time though. I crosscompile the emu in Linux typically, which builds properly.
I just ran a emulator build on my Windows machine (make TARGET=emu_devo10 WINDOWS=1) and it went through fine.
gcc --version
gcc.exe (GCC) 4.8.1
Copyright (C) 2013 Free Software Foundation, Inc.
This is free software; see the source for copying conditions. There is NO
warranty; not even for MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.
20 Mar 2015 22:35 #29970 by goebish
Replied by goebish on topic WLToys V912/V915/? protocols
Thanks, I guess there's a problem on my side then, I remember I've already built it before.
gcc 4.7.2, but this is a compile time error complaining about different return types (int vs void)... I thought my sources were up to date, but I'll check that.
20 Mar 2015 22:57 #29974 by goebish
Ok, I can build it but not from the sources on my repo although I thought I merged like 2 or 3 days ago...
Now this means I've no idea of which version of the source I'm working on....
I got lost with all those repos and branches :blush:
20 Mar 2015 23:09 #29976 by victzh
Replied by victzh on topic WLToys V912/V915/? protocols
Then make a diff "hg diff >somefile" and get fresh sources and patch them "patch -p1 <somefile".
20 Mar 2015 23:11 #29977 by PhracturedBlue
You can see it here:
bitbucket.org/goebish/deviation/history-...u/radio.c?at=default
you have the wrong A7105_Reset in radio.c. This code seems to have come from the 4.0 branch rather than trunk. This doesn't look like a general issue with your repo though. Not sure how you got it into this state.
20 Mar 2015 23:14 #29978 by goebish
PhracturedBlue wrote: Not sure how you got it into this state.
Me, when playing with Mercurial/SourceTree:
(I'm more of a git guy, I should learn hg...)
21 Mar 2015 02:44 - 21 Mar 2015 12:42 #29979 by goebish
I compared channel hopping sequence from capture file with the one I have with the same tx id in deviation (emu) and there's a slight difference:
capture : 4C, 92, 42, 88, 38, 7E, 2E, 74, 24, 6A, 2A, 60, 10, 56, 06, 9C
dev emu: 4C, 92, 42, 88, 38, 7E, 2E, 74, 24, 6A, 1A, 60, 10, 56, 06, 9C
Maybe this can explain this copter (V912) does not work well with my latest firmware ? To confirm that I can build a dfu with this fixed id and hardcoded hops sequence to check if this fix the problem (after some sleep :p).
But this is only 1/16 packets... probably not enough to even notice.
Deal57, can you make a capture on the RX side ?(edit: maybe we can check a few other things before having do to that).
I've a problem with the 4 files you posted earlier, saleae logic software does not show anything when I open them. Which version are you using ?
Last edit: 21 Mar 2015 12:42 by goebish.
21 Mar 2015 03:28 #29981 by Deal57
Replied by Deal57 on topic WLToys V912/V915/? protocols
I am using 1.1.34beta. Maybe I saved them wrong? Is there a format I should use?
Let me know if you need that RX capture.
21 Mar 2015 03:29 #29982 by goebish
My version is older, I'll update, but going to bed now :)
21 Mar 2015 13:58 #29991 by goebish
yeah, works better with updated version...
I wanted those files mostly to check timings, and there's no problem with that, time between start of packets is fine (a bit less than 1.5 ms).
Attached is a dfu in which I've set an hardcoded TX id (same as your stock TX) and an altered FlySky tx_channels table. Can you tell if it works better ?
Then... there's one more thing I've not checked that could be the cause to your problem: chip init, maybe there's a difference in VCO calibration or something like that... I'll check later.
21 Mar 2015 14:33 #29992 by SeByDocKy
Replied by SeByDocKy on topic WLToys V912/V915/? protocols
goebish wrote: yeah, works better with updated version...
Can you post the new code in your repo ? I can test also I got also a V913 ...
21 Mar 2015 14:37 - 21 Mar 2015 14:56 #29993 by goebish
keep in mind that is just crap code for testing V912, which is different from V911, no idea for V913 ...
gist.github.com/goebish/cd68d0928d37f81df027
Regarding my repo... I'll keep it for reference but I'll now work on a new fork, that'll be simpler:
bitbucket.org/goebish/deviationtx
Last edit: 21 Mar 2015 14:56 by goebish.
21 Mar 2015 14:56 #29994 by Deal57
goebish wrote: keep in mind that is just crap code for testing ...
You do good stuff! This totally works! The accessory buttons are working great. I saw absolutely no hesitation on the collective, and I walked through the whole house without losing bind. I haven't flight tested so let me know when it's ready for that.
21 Mar 2015 14:58 - 21 Mar 2015 15:25 #29995 by goebish
Ok, that's cool but we're not done :p
Now we've to make it work with any tx id... I think I need to replace all the 0x1e with 0x2e in tx_channels[ ][ ] for this particular protocol (I wonder if this is intentional or if they made a typo when they coded their firmware , because that's stupid to change only 1 byte in the sequence)... or maybe that's more complicated than that in which case I'll need a few RX captures, to check which rf channels it listens on.
I'll build a few more firmwares you'll have to test ;)
Last edit: 21 Mar 2015 15:25 by goebish.
21 Mar 2015 15:22 - 21 Mar 2015 15:52 #29996 by goebish
Deal57 wrote: I haven't flight tested so let me know when it's ready for that.
If you think there's a solid link you can try, just don't try another flysky aircraft with this firmware.
Last edit: 21 Mar 2015 15:52 by goebish.
21 Mar 2015 16:13 - 21 Mar 2015 16:14 #29997 by PhracturedBlue
if you can get rx captures, it will make it clear what channels it listens on, but for each row in the table, the numbers are the same. I don't think it would be too helpful though.
If you look at the table, you can see the rows come in pairs, with the 2nd being the 1st reversed (so there are really only 8 unique rows)
the 2nd number is always the 1st plus 0x50, so there are really only 8 unique bytes in a row.
in the 1st row, the bytes are in ascending order, and grow by 0x0a for each pair.
So it would be trivial to take the 16x16 table and turn it into an 8x8 table if we ever need more space. Based on the above, I would guess there is probably also an algorithm to determine the row scrambling, but I was never able to figure that part out. If we asume the 1e->2e is a typo (very likely), that strengthens the argument that there is an algorithm to determine the row scrambling, since it is unlikely they would make the same typo in each row (or more precisely that they don't use a table like ours when computing the channel)
Last edit: 21 Mar 2015 16:14 by PhracturedBlue.
21 Mar 2015 16:19 - 21 Mar 2015 16:31 #29998 by goebish
Yup, I noticed the +0x50 (I'm new to the FlySky protocol, I don't even have an aircraft that uses it...)
Now maybe they made the mistake only in this row (0x01), I'll write something to check that. And yes in last resort a few RX captures with different tx IDs would help.
Last edit: 21 Mar 2015 16:31 by goebish.
21 Mar 2015 16:59 - 21 Mar 2015 17:27 #29999 by goebish
Deal57 can you try this firmware with a few different fixed tx ids and report if it works please ?
edit: oops, made a mistake, reuploaded ...
Last edit: 21 Mar 2015 17:27 by goebish.
21 Mar 2015 17:42 #30000 by Deal57
I'll load that. Just for grins I took some RX captures if you want them. It's really TIGHT to work on that little RX!
RX Bind move collective
RX Bottom Button
RX Power no bind
RX THR RUD moves
RX Top Button several presses
21 Mar 2015 18:01 #30001 by Deal57
I used the updated one you posted and although it binds, the collective servos are hesitating and sometimes respond badly, like before. It also seems to lose bind then get it back. The buttons work up and down but again they sometimes don't respond and hesitate.
Time to create page: 2.287 seconds
