SYMA X5C-1, X11, X12
28 Apr 2015 05:41 #31731 by Durete
Replied by Durete on topic SYMA X5C-1, X11, X12
I think Speedo is talking about fly a new X5 BNF with his old X12 TX.
@Speedo, yes, is possible, but take in consideration the probably low range for the X12 TX.
16 May 2015 20:25 #32658 by cfl246tho
Replied by cfl246tho on topic X12S new protocol?
apparently there is an X12S model out. Frequent Flyer has done a demo, and says it doesn't bind to his Devo. I'm wondering if Syma has introduced some new protocol on this newer X12 variant.
Quads: Syma X5, X11, X12; LishiToys L6052; NiHui U207, CG023; H7/SpaceTrek M9912; BayangToys X7; UDI U839/939; WLtoys V676; Cheerson CX205
04 Jun 2015 04:21 #33410 by john
Replied by john on topic X12S new protocol?
Hi guys
I made a modul to bind x5c orginal. I use flysky 9ch . But i can not control it , when i move throlte, all motor max speed . I try setup all channel ,but fail , what do i miss ?
channel 1 ail
channel 2 ele
chanel 3 thro
channel 4 rudder
channel 5 hold
chanel 6.....
05 Aug 2015 12:21 #36579 by vasiliy_gr
Replied by vasiliy_gr on topic SYMA X5C-1, X11, X12
Received today X12S (yes - 'S'). It does not bind with latest nightly (tried 7e and 10). Ok, some experiments. On one side: X11, X12, X12S, X13. On the other side: all the TX-s I found.
1. Devo: binds everything except X12S.
2. X12S TX: binds everything except X11.
3. X13 TX: binds everything except X11.
4. X11 TX: binds everything except X12S.
5. X12 TX: binds everything except X12S.
So as you can see - X13 seems to be transitional model. As it binds every TX and its TX is compatible with X12S. Also the original X12 is semi transitional, as it binds every TX but its TX is not compatible with X12S.
So I think that differences in protocol can be studied both on X12S and X13 TX-s.
11 Aug 2015 02:39 - 11 Aug 2015 02:40 #36766 by goophoba
Replied by goophoba on topic SYMA X5C-1, X11, X12
I have a question. I'm having trouble using the Symax protocol. It's difficult to get my x5c-1 or x11 to bind. Once it is bound, for about the first minute, the copter is jerky in its movements then the movements smooth out and it's perfect until the copter battery dies. This is only an issue on the Symax protocol, the others bind first try every time and fly fine.
The problems aren't exactly the same every time, sometimes its harder to get it working, sometimes it just works, and sometimes it wont work at all.
I have a 7e with the MJXq test build. I tried the latest nightly build also and it also has issues. I am in a wi-fi heavy area but also had issues in a middle school baseball field. Any ideas?
Last edit: 11 Aug 2015 02:40 by goophoba.
11 Aug 2015 05:24 #36769 by SeByDocKy
Replied by SeByDocKy on topic SYMA X5C-1, X11, X12
goophoba wrote: I have a question. I'm having trouble using the Symax protocol. It's difficult to get my x5c-1 or x11 to bind. Once it is bound, for about the first minute, the copter is jerky in its movements then the movements smooth out and it's perfect until the copter battery dies. This is only an issue on the Symax protocol, the others bind first try every time and fly fine.
Pretty strange ... I always had a solid connextion with the SymaX protocol. Except if you set output power to minimum (but I am sure you don't...) It's strange. You did the correct pinout associated with the version 4.01 and above ?
11 Aug 2015 14:38 #36776 by Durete
Do you have CE and VCC signals bridged into your nRF24L01 module?
This behaviour sounds to me that you don't have the CE signal connected to 3.3V.
11 Aug 2015 16:31 #36786 by goophoba
I followed this pinout guide.
I think I did alright but I can't open and confirm until I get back home from vacation. I have no allen keys.
11 Aug 2015 20:20 #36803 by Durete
Daryon's pinout is right, but worth to check the wiring again because as Seby wrote before, I never had any single issue with SymaX protocol.
I have the same wiring as you ;)
21 Aug 2015 06:12 - 21 Aug 2015 06:15 #37093 by jorgegutz
Replied by jorgegutz on topic SYMA X5C-1, X11, X12
First time posting here and im having an issue enabling my second module (nrf24l01+) after upgrading it to the latest nightly build (deviation-devo7e-v4.0.1-ef0d76d). with the RC4.0.1 i didnt have any issue enabling it. any suggestions? thanks in advance!!!!
; enable-cyrf6936 = B12 enable-nrf24l01 = A14
has_pa-cyrf6936 = 0 has_pa-nrf24l01 = 1
enable-a7105 = A13 ; enable-multimod = A13
has_pa-a7105 = 1
enable-cc2500 = NONE
has_pa-cc2500 = 0
Last edit: 21 Aug 2015 06:15 by jorgegutz.
18 Sep 2015 10:27 #37847 by IKKI
Replied by IKKI on topic SYMA X5C-1, X11, X12
No news yet for syma X12s? I noticed that as soon as I try to connect flashes more slowly. But does not bind.
24 Sep 2015 23:48 #38033 by Richard96816
Replied by Richard96816 on topic SYMA X5C-1, X11, X12
Perhaps an ID problem?
25 Sep 2015 05:17 #38042 by Durete
Syma is using now this new protocol version in all his aircrafts, including the old X5C-1 and X11.
I'm pretty confident is a minor change at the protocol, and probably easy to implement, but someone should capture SPI traces from a new version TX.
Sorry, I can't help here, I don't have any aircraft using this new protocol version.
01 Oct 2015 20:23 #38327 by 30secs
Replied by 30secs on topic SYMA X5C-1, X11, X12
Hey guys --- same here. just got this x12 red from Amazon but was disappointed to learn it does not bind with the DEVO7e. Any updates on that?
www.amazon.com/Syma-Mini-6-Axis-Channel-...copter/dp/B00VVP31EK
05 Oct 2015 00:34 #38426 by 30secs
Can someone please help us x12s owners to get it to work? If it's not working it shouldn't be included in the thread title..
05 Oct 2015 05:28 #38431 by Durete
30secs wrote: Can someone please help us x12s owners to get it to work? If it's not working it shouldn't be included in the thread title..
Where do you see X12S in thread tittle?
Did you take some time reading the forum rules about protocol requests?
With that attitude is very likely you will not have any help at all...
07 Dec 2015 11:15 - 11 Dec 2015 11:44 #40650 by headlessagain
Replied by headlessagain on topic SYMA X5C-1, X11, X12
Had my Syma X5c (original one) flying great with my Devo 10. I then loaded the nightly build "devo10-v4.0.1-583c468 onto my DX10 to allow me to fly Bayang protocol models. Problem, none of the models flying with the NRF24L01 would bind!
It was suggested on the RC Gruops Devo hacking thread that I try latest hexfet's combo build
www.deviationtx.com/downloads...protocol-combo
This got me back in business but I have an issue with my Syma X5c. As soon as I give it lots of roll or pitch input it auto flips. This makes it somewhat difficult to fly!
My Eachmine H8 quad inputs are also screwed up with it rolling instead of pitching . I still can't bind with my FX071c heli as I only have the KN protocol to choose whereas I understand it should be KNFX. Help!
Sorted the Syma X5c issues by trying a different ini file obtained over on RC Groups
Last edit: 11 Dec 2015 11:44 by headlessagain. Reason: Issues part solved
16 Dec 2015 15:34 #40975 by vroomvroom
Replied by vroomvroom on topic SYMA X5C-1, X11, X12
Awesome. looks like the Syma X12s is working with Deviation 4.0.1-583c468. Surprised it worked with my Devo 7e.
16 Dec 2015 15:37 #40976 by IKKI
and which protocol?
16 Dec 2015 16:16 - 16 Dec 2015 16:20 #40978 by vroomvroom
SymaX if I recall. Here is the ini file I used. I didn't create it, I downloaded it somewhere on the forum so I can't give credit to the person who made it. The hold switch is for flipping.
File Attachment:
File Name: symax12-model4.ini
File Size:5 KB
Last edit: 16 Dec 2015 16:20 by vroomvroom. Reason: added ini
Time to create page: 1.178 seconds
